81 Ground Clearance
Old May 15, 2008 | 10:58 AM
Jon Hekking's Avatar
Jon Hekking
Default 81 Ground Clearance
I need some help, I have an 81 I will be shipping to SLC from KC when I move and the transport company needs to know the ground clearance. Unfortunately, I'm in SLC and can't measure it myself. Anyone know how much clearance an 81 has? Mine is all stock and I need 4 inches or more to get it on the classic transporter.
Thanks in advance.
Old May 15, 2008 | 11:13 AM
Jims79's Avatar
Jims79
Thanks in advance.
You should be fine. The only part that may touch is the exhaust pipes at the bend before the mufflers, 4" is very close here.
Old May 15, 2008 | 06:18 PM
BKarol's Avatar
BKarol
Do you have one of those free Restoration packets from GM? Its in there.
On my 78 it reads:
Minimum ground clearance 4.3 (catalytic converter)
Tire well to ground 4.5
Just dont have someone heavy drive the car in
Old May 15, 2008 | 07:45 PM
corvette8189's Avatar
corvette8189
i just went out and measured my 81 and it has 4.5 in. from the rubber piece to the ground on the front. the lowest part of my exhaust had just about 4 in.
To 81 Ground Clearance
