Noisy radiator fan
Old May 16, 2008 | 08:31 AM
Doinit Once's Avatar
Doinit Once
Default Noisy radiator fan
When I bought my '75 years ago it had a flex fan on it bolted directly to the water pump flange; no fan clutch and noisy at RPM's. I bought an aftermarket clutch and that didn't help much. Bought a used stock 350 fan and that didn't help. Any suggestions to eliminate this "problem"?
Very annoying to hear the fan over the sound of the quadrajet when I get into it.
Mike
Old May 16, 2008 | 08:58 AM
Binnie77's Avatar
Binnie77
Perhaps it is the water pump itself making the noise????
Old May 16, 2008 | 09:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You say the aftermarket fan clutch didn't help much; the implication being it helped a little. The stock GM fan clutch is supposed to quiet the stock fan. They're pricey, but might be worth the cost.
Old May 16, 2008 | 10:20 AM
rihwoods's Avatar
rihwoods
Agree with above...if you have "fan roar" with a fan clutch,it may also be a severe duty clutch,than a standard one...
See Hayden web site for more info...
To Noisy radiator fan
