Radiator date codes
Old May 20, 2008 | 02:05 PM
dmayhew's Avatar
dmayhew
Default Radiator date codes
I purchased an original radiator that will fit a 69 thru 72 small block 4 speed car.
There is a removable metal date date with MK9 on it.
Can some one explain how that code is read?
David
Old May 20, 2008 | 06:40 PM
Alan 71's Avatar
Alan 71
Hi David,
I assume you're talking about a copper radiator? Is the tag on the passenger's side tank? The MK could be the broadcast code ( is it embossed? ) used by the worker on the line to identify the proper part to put on the car. Some times there's a part number stamped on the same tag. I need to search a little to find something about the '9'.
Regards,
Alan
Old May 20, 2008 | 09:28 PM
dmayhew's Avatar
dmayhew
Originally Posted by Alan 71
Hi David,
Regards,
Alan
Hey Alan , Yes this is a copper radiator. The tag which was clipped to the radiator tank on the right side about even with the COLD FILL line did have the MK9 stamped into it.
David
Old May 20, 2008 | 10:11 PM
wallifishrmn's Avatar
wallifishrmn
My 71 has a copper radiator with the MK9 tag. The NCRS judging book doesn't say anything about dates on copper radiators ONLY on aluminum ones.
Old May 21, 2008 | 07:39 AM
dmayhew's Avatar
dmayhew
Thnks you Walleyefishermn
This info help out a lot
David
To Radiator date codes
