Water in power steering fluid?
Old May 20, 2008 | 07:10 PM
Shoevette's Avatar
Shoevette
Default Water in power steering fluid?
After I heard the tell tale "whirring" noise when I turned in the '69, I knew I had a power steering issue. Once I managed to find the resevoir under the alternator, I found that the level was below the dipstick. SO, I ran over to PB and grabbed some fluid and poured some in. When I looked in with a flashlight, I saw a clear fluid and am thinking it is water. I see no red in it, despite the fresh fluid I just added.
Is this a common occurence? Any suggestions??
Old May 20, 2008 | 07:57 PM
moosie982's Avatar
moosie982
Dunno if this will help or not but I just siphoned out the P.S. Pump on my D.D. 2000 Z71 Silverado cause it was whineing and the new fluid that I put in was rather clear, and the noise and poor steering assist have been fixed, for how long ?,,,,,,,,,,,,,,dunno that either. Peace,,,Moosie
Old May 20, 2008 | 08:06 PM
halfmoontrail's Avatar
halfmoontrail
Power steering fluid is clear.
Automatic transmission fluid is red. It works well in power steering systems, and is commonly used for this purpose.
Steve
Old May 20, 2008 | 08:47 PM
spedaleden's Avatar
spedaleden
Power steering fluid is clear. If you want to flush the system it is easy to do.
Remove return line from back of PS pump.
Route hose into a container.
Fill pump with new fluid and start car. Keep adding new fluid in pump and car car will automatically replace old fluid with new.
Turn car off, replace hose and check level.
Old May 20, 2008 | 09:46 PM
Shoevette's Avatar
Shoevette
Well, that explains why the clear liquid appeared to have some thickness to it -- I figured it was just the awkward position I was in, leaning over the fender, looking back and under the alternator. Strange, though, that the Valvoline product I used is labled as power steering fluid for high mileage use.
Thanks for the help.
Shoevette
Old May 20, 2008 | 10:52 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Shoevette
I have heard that trans fluid is used in almost every auto product claiming to be for high mileage , or marble mystery oil due .to the cleaning properties trans fluid holds. I'm not sure how true this is although.
Old May 21, 2008 | 07:38 AM
Jim Shea's Avatar
Jim Shea
If you get water introduced into the power steering system you will quickly know it. The water molecules will change to steam as they pass through the pumping section of the pump and you will hear loud popping noises coming from the pump.
The fluid in the system will look milky. You will have to flush the system to remove the residual water from the system.
This isn't very common but with salvage gears, pumps, hoses, etc laying around for years, rain, condensation, is always possible. Particularly when you don't know the history of your parts.
Jim
To Water in power steering fluid?
