Question re POR 15
Old May 22, 2008 | 01:12 PM
Maymyvetteliveforevr's Avatar
Default Question re POR 15
Before using POR 15 can I just powerwash the metal? Only have the Por 15, not any other pre stuff, therefore I was just going to use engine degreaser and powerwash, then let dry and apply with a brush.
Old May 22, 2008 | 01:20 PM
1stCorvette69's Avatar
1stCorvette69
Default Por 15
BE CAREFUL POR 15 only sticks to Rusted metal...or treated metal. I would treat the metal with an Etch Like Rust Mort then wash the rust mort with water let dry then paint it with POR 15
CA-Legal-Vette's Avatar
CA-Legal-Vette
Hopefully others more knowldgieable will chime in, but I think you're ok. I've used it on parts that were preped according to their instructions and it worked very well. I've also used it on parts that were washed in a dishwasher and still rusty. Worked fine on them too.
My understanding is that grease and oil will prevent proper adhesion. If you get that off, you should be ok. Testing in a less visible area might be a good idea though.
Old May 22, 2008 | 01:25 PM
Kellys~hotrods's Avatar
Kellys~hotrods
You must have a very understanding spouse lol. If i tried that mine would be
Old May 22, 2008 | 01:28 PM
stinger12's Avatar
stinger12
Just do it when your wife isn't home
I suggest you follow the prep on the por15 instructions. I personally hate the stuff, but if I were you, I'd get the correct prep products that they sell and follow their instructions.
CA-Legal-Vette
Yes very understanding, though she would be less so if she found out
Old May 22, 2008 | 02:09 PM
Erik016's Avatar
Erik016
It can work if you apply thicker coats. I prepped it with metal ready after i degreased and power washed it. I have used it on off road stuff before and it worked pretty good without a prepping solvent. http://forums.corvetteforum.com/show....php?t=1936313
Old May 22, 2008 | 02:37 PM
Thanks for the info everyone, I forgot to get the metal ready or prep stuff and I need to do it this weekend since it's the only available time I have, so I'll just degrease it then power wash it and keep my fingers crossed.
Old May 22, 2008 | 02:48 PM
Scott Marzahl's Avatar
Scott Marzahl
POR 15 has good tech support.
Old May 22, 2008 | 06:10 PM
I'm sure if I called there tech support there standard answer would be.....for best results use the recomended procedure as listed on our web site. If you don't follow the proper procedure then the results may not be as desired, therefore warranty will not be valid.
Old May 22, 2008 | 07:00 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
They offer a warranty? interesting...
Good Luck Frank, Call me if you want some help this weekend.
Old May 22, 2008 | 07:25 PM
1stCorvette69
Default Por 15
Hello ,What ever you do wear two pairs of gloves, Don't get that stuff on you.. It,s realy nasty to get off..
To Question re POR 15
