Rust Question......
I scrubbed all parts with a Scotch Brite pad, so it was very clean. Then apply the Metal Ready. You only need to wet the clean metal and let it dry. It will leave a white powdery film when dry. In some places it would brush off, so I quickly brushed the loose powder off before applying the POR 15. The rusty but clean parts will look amazing after the paint. I used one coat of gloss black on my frame and it looks as good as new 18 months later. I clean the underside of my car, so I monitor its condition regularly. My fuel tank and lines were painted in silver and also look as just painted.
I asked a similar question when I did my carpets and floors 4 years ago. I got lit up by several members for thinking my '80 had metal floor pans. Luckily the later C3 owners came to my rescue.
Vacuum the inside of the frame of as much loose material as you can. Go to your building supply store and by a PVC reducer from the plumbing department to fit on the end of your vacuum. You may need to reduce it twice to get a hose small enough on the end that will fit into the frame.
The plate at the end of your frame rail has drain holes at the bottom corners. Poke a small rod into them to free up material collecting there and blocking it. Out of mine came rust particles and the remains of a rat nest. You will want to run a hose into the frame after you have done the hammering and vacuuming. After you have it as clean as possible, it is ready for a coating. I sprayed mine using a cheap spray cleaner from JC Whitney, I think. It is powered by an air compressor and works on a vacuum principle. One end goes into the material to be sprayed and the vacuum created by air going by draws the spray material. I simply put it into the frame holes and srrayed until it ran out of the frame. Remember, the frame is made of two pieces welded together, so there are gaps along the bottom that provide drainage.
I don't think you can go wrong coating the inside of the frame with any material that is advertised to retard rust. I would think POR would work well and from my experience would prefer it. There are many other options that would probably work as well. I hope this gives you some ideas to get started.
Ummm...yeah. Obviously whoever powdercoated your parts did a terrible job of prepping the parts, or didn't completely cure them. Powdercoat is tough as nails. When I have to strip powdercoat, I have a hell of a time removing it - and that is using aircraft stripper.
As a side note to anyone considering powder coating I'd share this: shop around on prices. I had one guy charging me more than I thought was reasonable and should have compared prices. By accident, I found another guy doing the same work for about half what I had paid.
From my experience I know I can trust POR and my labor. When I have other people do things for me it is always a gamble. That applies to everything and not just powder coating.
Yes, I think you've been had. Powdercoat is not paint. It is a plastc powder that melts/flows out once heated.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]This was done with the body on and over the course of about six months. I was having everything out back freshened up, and thought 'while I was at it,' use the opportunity to clean everything. The gloss black POR holds up better than powder coating where grease and chemicals are involved IMO. My gas tank crossmember and front susp is powder coated; the rest of the frame, trans crossmember, gas tank and rear frame crossmember are POR coated. The underside fiberglass is brush painted with PPG epoxy primer. All fiberglass bonding seams have been molded in the four wheel wells.
You can do this to your new 73, but enjoy driving it until maintenance needs to be done. Then, put your plan into action. My floor pans were painted with PPG as are the #2 body mount areas behind the kick panels.
BTW...I also powdercoated my differential, half shafts and DS in chrome powder. Next time, I will POR the shafts, TA's and diff in gloss silver, as it much easier for way less $$ and looks as good IMO.
[IMG]
[/IMG]There are two types of powder coating: epoxy and polyester. I understand that epoxy is the tougher of the two options but - like POR15 - it doesn't enjoy sunlight.
I've just stripped a load of paint from various fixings on my chassis, including the bush retainers on the A-arms, which I had powder coated with epoxy last year as part of a suspension rebuild. Paint stripper had no problem removing the coating just like it did the other paints.
I've also cleaned the arms up using standard hydro-carbon degreaser and that dulled the semi-gloss finish, so PC is by no means immune from chemical attack.
These are just my experiences.
More info about powder coating here -> http://www.pcfpowder.com/allaboutpc.html
It seems it should work the same, except they're cheaper and I don't have to worry about loose bristles. Thoughts?
Forgot to mention this...I talked to a guy at the auto shop and he recommended doing one area at a time (i.e. wire brush/chip off dirt - Marine Clean - Metal Etch - POR15). He said if I try to do the entire underside one step at a time (i.e. wire brush entire frame first), I'd just end up w/ the clean surface flash rusting in a day or so (it's been really humid here). Do you think I'll be OK doing manageable sections at a time? There's obviously no way you could do the whole thing in a day (I wish!), so this seems to be the only real option. What would you recommend?
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[IMG]
[/IMG]I can't find a picture, but most C-3's have a void in the splash apron behind the front wheel and leading to the rocker channel. This allows water and debris back and into the channel, so I wanted to close it. I used some SEM adhesive to bond the screen material that comes with a can of Bondo over that opening. Then, use Bondo to cover it and blend it into the main splash apron. When everything is smooth it is ready for paint.
On the underside I used a cheap 1" bristle brush and foam brush to paint the tight spots and a small foam roller brush for the large areas. You will find the roller does a very nice job that keeps the texture uniform. My roller brushes were bought from Wal Mart's paint dept. You will probably need several rollers, so buy a brush where extra rollers are available. Any pause in your painting and the roller will dry and need to be disposed. I used PPG DP primer paint for the fiberglass underside. It comes in several colors to select from. Add about 1/3 more hardner when you mix it and it will take on more gloss. I prefer a semigloss finish over flat, as it cleans better and I just prefer it. One quart will do your entire underside with paint left over. One qt is the smallest quantity you can buy and the hardner is seperate. You will need extra hardner when going for the glossier finish. Remember to mix the same, or the texture will change from batch to batch. That is all I used and no topcoat is necessary. You will need to give bondo areas a second or even a third coat, as it soaks up the paint and leaves a flat finish.
Now for the differential rebuild: unless you are set up with the tools and experienced in the process, send it out. If you are building performance into your engine and plan on doing some racing, use new screw in yokes. Before leaving your differential at a shop explain what yoke end play you expect when they are finished. If they can't guarantee providing what you expect, take it elsewhere. Ship it to Gary1999 and you can be assured it will be right. Do a search for his letter on rebuilding a differential where he has all the specs you need to know. Ditto for the T/A's.
I rebuilt a set of T/A's before the internet and access to shims and proper tools, so I winged it. The wheels turned fine and I put a few hundred miles on them, but ultimately had them redone properly by a shop. Getting the spindel bearing shimmed to specs is difficult without the proper tools. Since I do not do it often, it is cost effective to send it out. The caveat is, send them to a shop that will meet your expectation. Anyone can take them apart and reassemble with new parts, getting them right is what you want to be paying for. I hope this helps get the result you want!
So, it's not a problem using lacquer thinner on the glass? I've already power washed mine and it looks to be bare glass.
I was thinking the same thing.
