Power Antenna
Old May 29, 2008 | 08:27 AM
nichboy's Avatar
nichboy
Default Power Antenna
How do i access the power antenna unit for repair on a 82 corvette.
Old May 29, 2008 | 08:38 AM
...Roger...'s Avatar
...Roger...
Easiest way is to remove left muffler.
Old May 29, 2008 | 10:59 AM
nichboy's Avatar
nichboy
Is there any documentation available on removing or repairing antennas on a 82 model.
Old May 30, 2008 | 05:40 AM
hunt4cleanair's Avatar
hunt4cleanair
Shop manual is probably the best source. Can you hear the motor running? If that's the case, than replacing the weed eater cable will probably work. It can get more complicated after that.
If the car has been fondled by bubba, it could be anything from mechanical to electrical including connections to the radio, the power antenna relay, etc. So you need to do some troubleshooting.
I've gotten away at dropping the left muffler to access the antenna. Get a test light and determine if you've got power to the unit. Isolate if its in the unit or up the line. I'll assume you've checked the fuse.
The 82 Corvette Shop Manual has a nice troubleshooting guide along with circuit schematic. Others may have it scanned and can post. If not drop me a note and I'll scan over the weekend. Also shows location of the relay (console).
Old May 30, 2008 | 06:15 AM
stingr69's Avatar
stingr69
Unbolt the exhaust system at the rear of the catalytic converter (4 Bolts) and the whole rear y-pipe and muffler assy will basicaly fall out giving you plenty of access under there. You will need to unscrew the bezel from the top. The wiring harness unplugs from inside the passenger compartment. Pull the carpet away over the rear drivers side wheel well area to find the harness plug and the rubber grommet that you will need to push out to the rear of the car to get the wires disconnected. You should be able to take it from there.
-Mark.
Old May 30, 2008 | 01:25 PM
reelthing's Avatar
reelthing
I was able to remove my old ant. without taking out the muffler. I was able to get my arm up thru the fender well from underneath to un screw.
To Power Antenna
