Openion on Comp Cams
Old May 30, 2008 | 11:49 PM
LT1driver's Avatar
LT1driver
I am a crane cam fan myself, I think they have the best retro cams out there, as stated GM uses them for the old solid cams.
Old May 31, 2008 | 07:08 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by dmayhew
I need to put a solid lifter cam back in my 1971 350 car.
Does anyone have pro or cons to report on the brand name
COMP CAMS
They make a cam with the GM profile for the 330 HP
David
Is your '71 an LT-1? I think that's the only engine that might have used a solid lifter cam in '71. Since you're replacing the cam, why don't you see if you can go a little more aggressive? No one will know.
Old May 31, 2008 | 08:21 PM
dmayhew's Avatar
dmayhew
Yes , it is an LT-1 , A previous owner installed a hyd. cam back in 1985.
David
