Openion on Comp Cams
Old May 29, 2008 | 09:18 PM
dmayhew's Avatar
dmayhew
Default Openion on Comp Cams
I need to put a solid lifter cam back in my 1971 350 car.
Does anyone have pro or cons to report on the brand name
COMP CAMS
They make a cam with the GM profile for the 330 HP
David
Old May 29, 2008 | 09:25 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Comp Cams I believe are the bet in the aftermarket cam business and any questions you need answered call the tech line, They even will tell you if you ask that a Competitor has a better design on the cams you are asking about.
Old May 29, 2008 | 10:16 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
I always found their tech line useless full of unpleasant people.
I would rather not buy from them.
Old May 29, 2008 | 10:34 PM
thoyer's Avatar
thoyer
I Have used Comp Cams in the past and have had no complaints. I had only one experience with their customer service. I used to race a big block Camaro. Had a very stoudt high lift roller lifter cam in the engine. On a bearing inspection between weekend events I found the indexing pin for the timing gear in the oil pan. Pulled the timing cover and sure enough it had worked its way out of the front of the cam ( I have no idea how.....). Called Com Cams, told them the story and that I needed the cam fixed and back in the engine by the weekend. They had me overnight it to them, they pressed a new pin in and sent it back overnight all on their dime. This was back in the late 90's. Things may have changed now, but that was my experience.
When I needed the stock profile cam for my 71 LS5, I looked at Comp Cams first, but they did not have one so I went with Crane.....
They sell millions of cams acroos a wide variety of applications. They must be doing something right and I would not lose any sleep over using one of their products.
Tom
Old May 29, 2008 | 10:41 PM
mr nasty's Avatar
mr nasty
I have had nothing but good luck with their cams. They are my choice when it comes to buying cams.
greg
Old May 29, 2008 | 11:28 PM
TimAT's Avatar
TimAT
Another option here. (well a couple of them)
I just went to GM's Parts and GM dosen't even list any solid lifter cams for a SB. Holy camshaft!! And I had really good luck with that 3927140 cam too.
Old May 30, 2008 | 06:31 AM
stingr69's Avatar
stingr69
I just put a Crane F-278-2 solid lifter cam in my Camaro. This grind is very close to an LT-1 grind in application as the valve timing points are very close. I like it in my DZ 302
You can also get an exact copy of the LT-1 cam from Federal Mogul or Crane cams Blue Racer division. Jeg's has them under part number 270-969551.
Comp does not market an exact copy.
Scoggin Dickey sells a kit with the actual GM cam and lifters under part number 12364054
-Mark.
Old May 30, 2008 | 11:01 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I'm using a 282-s (solid) flat tappet.
A couple years ago, Comp had problem with their roller cams.
Old May 30, 2008 | 11:53 AM
Scott Marzahl's Avatar
Scott Marzahl
Crane cams p/n 969551 for the LT-1 cam. If you order a GMPP cam, it is made by Crane.
Old May 30, 2008 | 12:00 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
As far as comp cams goes, I have used them on everything for the last 15-20 years. NEVER had a problem!!!!
Old May 30, 2008 | 12:07 PM
weimer20's Avatar
weimer20
Aside from using a GM cam once, Comp is all I have used. Never had a problem with them.
SteveG75's Avatar
SteveG75
Crane Powermax flat tappet - no problems
Comp XE 262 wiped in 5000 miles.
Comp XE 274 wiped in 500 miles.
My roller cam is Crane. Comp gets no more of my money.
Old May 30, 2008 | 04:49 PM
FKING1's Avatar
FKING1
Like their cam, but upon breaking one of their heavy duty valve springs found their Customer Service to also, be useless!
Old May 30, 2008 | 07:07 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I, too, got a bad service from their technical support team. I don't think I would buy anything from then any more.
Old May 30, 2008 | 08:30 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Very much like their product line. Living just a few minutes away, I've never run into anything I'd call "bad service", and although getting proficient help on many a tech line can sometimes be frustrating (particularly should you stray from the basic menu) both Bryan and Brock seem to care enough to find out anything they don't know off hand when I've dealt with them.
Old May 30, 2008 | 09:05 PM
TMU's Avatar
TMU
St. Jude Donor '09-'10, '15, '17
I like how they all charge more for a roller profile. Smacks of market fixing collusion to me. I talked to a a cam grinder and he said he would duplicate whatever pattern I wanted for something like $70 per cam.
Old May 30, 2008 | 09:25 PM
TheSkunkWorks
Can he get roller cores for flat tappet $?
To Openion on Comp Cams
Old May 30, 2008 | 09:28 PM
TMU's Avatar
TMU
It's been a couple years since I talked to them but here is their site.
http://www.oregoncamshaft.com/regrinding.html
Old May 30, 2008 | 10:18 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
We have 3 different cam combinations. The Comp is my favorite.
Old May 30, 2008 | 10:29 PM
bertmeister's Avatar
bertmeister
I have had good luck with Comp Cams here. Used three of there cam packages in the past 20 years and have had no problems. Lastest cam is the HE268.
