Help Decipher Antenna wires
Please forgive my crude drawing (below), but pix didn't give the detail.
The aftermarket antenna on my 79 has three wires entering it: yellow, white and brown. I need to know which wire does what.
I took out the antenna (an Audiovox) and opened it up to see what specifically the wires connect to. There is a plastic block with a circular copper disk in its center that rotates. There is a small cut-out in the copper at the edge of the disc. At the top of the block there are four spades. Three of the spades extend through the block and make contact with the copper disk. The fourth does not. There is a small capacitor (??) connecting two of the spades (#'s 1 and 3).
Of the spades that extend through the block,the ones on the outside (#'s 1 and 3) are shorter and mesh with the cut-out in the face of the copper disk. I'm guessing that once the antenna gets a trigger this disc will rotate and provide power to the motor until one of these spades encounters the cut-out and the circuit is broken. The center spade is longer and will always be able to contact copper on the face of the disc. It connects to the red wire of the drive motor.
The wires entering the antenna connect as follows:
Brown wire connect to the short spade on the left rear (#1)
White wire connects to the short spade on the right rear (#3)
Yellow wire connects to the spade on the right front (#4) taht does not extend through the block.
Another white wire also connects at spade 4 with the yellow wire. It connects to the antenna drive motor.
A red wire comes from the drive motor and connects to long spade #2, center rear.
The top drawing shows the block from the front; the detail at the bottom is how the wires connect if looking at the block from the top:
Here's a live shot:
I do not have the original relay and it is my understanding that aftermarket antennas using modern head units (ie Kenwood Excelon) don't need it. Therefore, what do I connect these wires to? One should be constant power, one ground and one the blue trigger from the HU. Thoughts?
Thanks to all,
Steve
You can test this by running a 12V wire from the battery and touching it to the suspect terminal while the IGN system is energized, and see if the antenna extends.
If I connect the brown to the pos and the white to the neg on my battery I should expect nothing to happen. If I then tap the yellow to the pos I would expect extension or retraction. Is this a safe way to test this?
Thanks to all, S
Probably not, because if it's wrong it could smoke the antenna. Problem is I can't think of a different way to 'test' without knowing more specifics about the antenna.
You can test it by hooking up 12V between #2 and #4 wires to see which combination makes the antenna go up and which makes it store. Be careful not to let the center disk rotate past either cutout while testing, it won't stop on it's own. once you know which combination makes the antenna raise +/- and which makes it lower, and which way the disk rotates when the mast is raising and which way it goes when lowering, i can draw you a schem, if you would like.
http://forums.corvetteforum.com/show...=power+antenna
On the two contacts marked Down and Up, one of them will go 1, the other to 3 .
If when the antenna is retracting, (Down), the disk is rotating the hole towards lead 1, then you hook up the 'Down' relay point to lead 1 and the other to 3
If when retracting (Down) the disk is rotating the hole towards lead 3, then you hook the 'Down' contact to lead 3 and the 'Up' to 1.
Or you can just buy a new Antenna that works on the single Blue wire
which is what I'd recomend
,, but this will work. C. (the 'Up & 'down' refered to are for the leads on the bottom of the drawing, NOT the referance up & down on the first upper set of contacts)
(this is ofcours assuming that the antenna retracts when lead 2 is at 12V and 4 is Grounded, if it works oppositly, Use the second Schematic)
Then, I took some advice I gave to a guy a few years ago at the audio shop...a windshield antenna.
It's fast and easy to install...wires hide behind the A-pillar trim, and it plugs right in and only needs a 12V source which can piggy back off of the 12V to the head unit.
I love mine, and I have it up in the top right corner of the inside of the windshield on the passenger side. It's hard to see unless you're looking for it, and it works great with all of the local radio stations.
The hole in back will have to be glassed or plugged, but to me it was a small price to pay.
http://www.crutchfield.com/App/Produ...na&i=12044UA20
