Engine troubles
Old Jun 2, 2008 | 01:29 PM
supert's Avatar
supert
3rd Gear
Default Engine troubles
My car has been idle for about a year and now when i try to start it it will start but it dies after about 5-10 seconds of idling. It will cut out sooner if i try and give it gas. I have disconnected the fuel lines from the tank and am running it from a new can of gas with the same results. Anyone have any ideas on how to get this thing running?
Old Jun 2, 2008 | 01:46 PM
halfmoontrail's Avatar
halfmoontrail
Sounds like clogged fuel filter, the one inside the carb inlet.
Steve
Old Jun 2, 2008 | 01:58 PM
jbierschwale's Avatar
jbierschwale
Sounds like you just need to go through your carb. Gas starts to go bad and turn into varnish within 4-6 months of sitting idle. It would be a good excuse to rebuild your carb... Take that puppy apart and soak it in a can of B-12. I think a rebuild kit for our carbs is $35 or so.
Old Jun 2, 2008 | 05:30 PM
7T1vette's Avatar
7T1vette
Fuel filter is most likely trashed. Pull it to see. If the paper element is deteriorated, don't try to start the car again....just remove/clean out/rebuild the carb as it needs. Pay attention to clearing all of the passages in the castings/drilled holes well to get the filter junk out of it.
To Engine troubles
