Do worn bearings = Emergency Replacement?
Old Jun 2, 2008 | 02:02 PM
81_vette!'s Avatar
81_vette!
Default Do worn bearings = Emergency Replacement?
1981, 4 speed manual, Muncie transmission.
I had it checked today and my bearings are worn.
No leaks, runs fine. (does make noise when in nuetral and clutch pedal not pressed down)
Is this a "must replace immediately" repair, or can I wait a while before I have the transmission rebuilt?
Cottman quoted: $1200 - $1400 for the rebuild (if there are no unexpected surprises).
Old Jun 2, 2008 | 02:10 PM
halfmoontrail's Avatar
halfmoontrail
From the limited information:
Sounds like your throwout bearing is worn, causing the noises. Yes, this can fail, and leave you stranded. No, >$1000 is not a good price.
They are MAYBE talking about a transmission rebuild, but probably not. RU sure it's a Muncie...thought the 'Vette was back to Saginaw from '74-on.
Steve
Old Jun 2, 2008 | 02:17 PM
81_vette!'s Avatar
81_vette!
The shop that did the transmission inspection thought I had a Muncie, but I don't know.
Yes, they are talking about a rebuild. Is $1200 - $1400 too much for a complete rebuild?
Old Jun 2, 2008 | 02:28 PM
milo30's Avatar
milo30
It should be a muncie. My 78 has a muncie close ratio also. As far as the cost of the rebuild, I haven't priced it yet but that's about what I was expecting it to be. I'm thinking very seriously about just removing it and replacing it with a 5 or 6 speed. The gas mileage sucks with the 4 speed plus I just don't believe that it is the best thing for the engines to always rev so high on the highway.
Old Jun 2, 2008 | 02:32 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I just rebuilt a Muncie from a friends camaro, we replaced the back up gear and bearings, Lets put it this way,,, I would rebuild them anytime for that price, If you have any mechanical nowhow you can do it yourself. the parts are not expensive.
Old Jun 2, 2008 | 02:35 PM
chris__2007's Avatar
chris__2007
i'd look for an overdrive swap...
for id on your current tranny if your case is cast iron it's a saginaw. if aluminum muncie.
Old Jun 2, 2008 | 02:58 PM
pbcanney's Avatar
pbcanney
Unless my research is wrong, the last year for Muncie in a GM vehicle was 1974
I would think all you guys (like my 4 speed) is a Borg Warner
see:
http://www3.sympatico.ca/atkinsom/history.html
Old Jun 2, 2008 | 03:46 PM
81_vette!'s Avatar
81_vette!
Default Is my issue with my clutch, not the transmission?
I have spoken with a half dozen shops at this point... and a throw-out bearing seems to be the answer I get from most shops. (a whirling noise when the clutch pedal is NOT depressed) This, as I understand it, is a clutch issue and would not require a transmission rebuild.
So I guess I will start there first, as my local shop can replace the clutch.
Now, the only question is do I have a 10 spline or a 26? Anybody know how to figure that one out without opening it up?
Old Jun 2, 2008 | 03:58 PM
pbcanney's Avatar
pbcanney
26 if it's a BW
Old Jun 2, 2008 | 04:05 PM
BKarol's Avatar
BKarol
You need to crawl under there and get numbers for the guy. The first site tells what trans came in that year:
http://www.corvette-world.com/corvet...on%20Codes.php
The second site is the BW site where you can find the numbers. Vertical on the drivers side will give you the w number and additional info. I dont think anyone can give any answers since the trans might have been changed. Need to find out what is there. IMHO
http://fiedlerh.home.att.net/BW.htm
Old Jun 2, 2008 | 04:37 PM
81_vette!'s Avatar
81_vette!
Thanks, guys.
This gives me a few ideas and places to start.
Old Jun 2, 2008 | 05:24 PM
7T1vette's Avatar
7T1vette
A throw-out bearing is not a tough fix, if you have basic tools, are under cover and can get the car in the air a couple of feet. Drop the driveshaft, remove the tranny, change the bearing, reinstall.
Old Jun 2, 2008 | 05:41 PM
milo30's Avatar
milo30
see:
I see what you're saying. I have never crawled under and looked at my tranny but have always assumed it was a muncie. Everywhere I looked on muncies it shows the same thing as the link you attached and it all stops after 74. After I bought my 78 I was deciphering the codes to see what it came with and below is what it showed as the standard and optional equipment, an M21 close ratio. I checked a couple of other years after 74 and they showed the same tranny listings.
So what does it have? I'll have to look when I get back home. I assumed that GM listed it with the M21 so therefore it was a Muncie. If your info is right, I guess they could have just left the M21 code for a 4sp. I did see a couple of sites that said GM dropped it from everything but the vette but there was nothing there to verify that on their site.
Now you're gonna make me get dirty to find out!
1978 Corvette Production and Performance
Available Options
RPO Description Price Production
1YZ37 Base Coupe $9,351.89 40,274
1YZ87/78 Limited Edition Pace Car $13,653.21 6,502
A31 Power Windows $130 36,931
AU3 Power Door Locks $120 12,187
B2Z Silver Anniversary Paint (Includes sport striping and two-tone paint treatment) $399 15,283
CC1 Removable Glass Roof Panels $349 972
C49 Rear Window Defogger $95 30,912
C60 Air Conditioning $605 37,638
D35 Sport Mirrors (LH remote and RH manual) $40 38,405
FE7 Gymkhana Suspension (Included with ZN1 trailering chassis equipment) $41 12,590
G95 Optional Rear Axle Ratio $15 382
K30 Cruise Control $99 31,608
L48 350ci. 200hp engine $525 34,037
L82 350ci. 220hp engine $525 12,739
M21 4-spd, Close Ratio Manual Transmission. $0.00 3,385
MM4 4-spd, Wide Ratio Manual Transmission $0.00 4,773
MX1 Automatic Transmission $0.00 38,614
NA2 Standard Emissions Equipment
Old Jun 2, 2008 | 07:30 PM
pbcanney's Avatar
pbcanney
and as an added caveat, the trans crossmember unbolts on the 81
To Do worn bearings = Emergency Replacement?
