Brake Bleeding Devices -
Old Jun 10, 2008 | 08:59 AM
nate99's Avatar
nate99
Default Brake Bleeding Devices -
I have used the tried and true two person method for bleeding brakes many times, however, now I am in a spot where I do not reliably have any help when I am working on my car.
Has anyone used something like THIS to bleed their brake system? If there is something else out there that is a better alternative, I'd like to hear it.
I've used the check ball type speed bleeders before too, but was wondering if anyone had any experience with something that either used an air compressor (which I have) or a hand pump to clear out the system.
Thanks.
Old Jun 10, 2008 | 09:52 AM
in2fun's Avatar
in2fun
Old Jun 10, 2008 | 10:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Jun 10, 2008 | 10:16 AM
THE TECH's Avatar
THE TECH
That's what I use!
Old Jun 10, 2008 | 10:29 AM
nate99's Avatar
nate99
Cool, that's what I was looking for.
FYI - here is the website...
http://www.motiveproducts.com/02bleeders.html
Old Jun 10, 2008 | 11:29 AM
Mark L. Warner's Avatar
Mark L. Warner
Speed Bleeders are so much easier to use and I have always have great results with them.
Old Jun 10, 2008 | 11:51 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Thats a real MAGIC tool, go and buy it NOW!
Old Jun 10, 2008 | 11:57 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
These are nice products,,,, You can also weld an air fitting on an old master cylinder cover or piece of steel with a rubber seal,, held down with a large C clamp, connect your compressor to it with about 20psi,,, works great !.
Old Jun 10, 2008 | 12:35 PM
TopGunn's Avatar
TopGunn
I use one of these also BUT I don't put any fluid in the thing. I fill the res and just use this to pressurize the system. One of these things comes off the top of your res. blowing brake fluid all over the place and you'll be one p-$$ed off person.
Old Jun 10, 2008 | 01:10 PM
Jim71Vette's Avatar
Jim71Vette
MITY VAC works well for me.
Old Jun 10, 2008 | 04:29 PM
Red70vette's Avatar
Red70vette
I tried the Mity Vac, 2 person bleeding and have found that speed bleeders work the best for a 1 man operation. Loosen them pump away, then tighten them and you are done. Clean, simple, and cheap.
Old Jun 10, 2008 | 05:27 PM
outlawkinser's Avatar
outlawkinser
I use this and Speed Bleeders. Piece of cake.
Mike
Old Jun 10, 2008 | 07:47 PM
seventysixvette's Avatar
seventysixvette
I just got my brake system all installed and going last Friday. I used this to bleed:
It's just an old vacuum pump with a canning jar screwed into a filter base. I used a clear tube from the bleeder to the catch jar. The fluid enters the side and drops down a 1/2" pipe nipple so's it doesn't get pulled into the pump. I pulled a lot of old, brackish brake fluid out of those lines.
This thing will empty a reservoir chamber in about 15 seconds, so you can't get carried away and forget to shut down and refill. When I was done I had hard, firm brakes the first time. No muss, no drips on the caliper paint.
John
Old Jun 10, 2008 | 08:10 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
That is a great idea. I'll have to try that next time. I hate it when I drip fluid onto the frame and steering box.
I tried one of the hand held vacuum bleeders. It didn't work for me.
Old Jun 10, 2008 | 09:14 PM
RunningMan373's Avatar
RunningMan373
The thing about the Motives, you can't use the supplied chains. Put a piece of 3/4" plywood or a steel plate and use a large C-clamp. I got so mad after useing mine brand new one, I sent them a nasty E-mail. they (motive) made me this- pic. they used to supply this steel adapter plate and it doesn't leak a drop. they went to plastic about 5 years ago. Love my steel adapter. Use a piece of wood and a C-clamp. C.
Old Jun 10, 2008 | 09:20 PM
jlelec's Avatar
jlelec
Only way to go!
Old Jun 10, 2008 | 09:26 PM
rcread's Avatar
rcread
I've been using the plastic lid with a c-clamp. What did you put on the bottom of the plate?
Old Jun 10, 2008 | 09:32 PM
RunningMan373
Motive actually made it for me. They're local out here, in berkely. I checked it out, it's the same seal they use on the plastic one, just glued on with some very strong adhesive.
Old Jun 10, 2008 | 10:27 PM
RMS73's Avatar
RMS73
I use
Just c-clamp it to the master cylinder and use a little. I made it clear to monitor the brake fluid level.
Roger
To Brake Bleeding Devices -
