Here is a pic of the shoulder belt retainer for the seat back.
The quarter trim is from a 70- up vert. Not a 69. I am using the Camaro belts and they mount on the top of the fender not on the side as the 69 shoulder harness does. The 69 trim is thinner at the bottom and flares out at the top to cover the top frame. The shoulder harness will come from the back low on the inside of the quarter trim and up to the seat back mounted retainer. Hope this is clearer than mud.
69 don't look like that, unless those pics are a conv?!?!?!?! I had a coupe and the shoulder belts mounted on the wheel humps in their own little assembly with a vinyl cover. Chrome guides are on outer edge of seat. "Fonz69" never says coupe or conv. in his post, unless it is common knowledge what he has.........................B
It does not say in the post, but if you look at his profile his car is a vert. Vert or coupe the shoulder harness assembly will be mounted on the inside of the wheel wells and should come over the seat thru the bracket. The coupe will not have the trim extending behind the seat as the vert does. And yes mine is a vert too.
