Overfilled tranny fluid
Old Jun 12, 2008 | 02:18 PM
kmobrien76's Avatar
kmobrien76
Default Overfilled tranny fluid
Had my VEtte tuned up months ago...I checked the dipstick and it's overfilled (tranny)...It leaks on my garage floor, annoying. Think it's a leak or would it come out (normally) from being overfilled.
Old Jun 12, 2008 | 02:47 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I think it's more likely that it would have leaked in any case though a higher level probably increases the flow. Not really hard to fix the seals(except maybe the front hub to converter seal) but you have to replace them to stop the leaks.
As an aside, are you measuring the fluid level with the car running? If not,you are not getting the true, working level.
Old Jun 12, 2008 | 02:49 PM
kmobrien76's Avatar
kmobrien76
Measured with it off...working level? Isn't that more so for the engine??
Kevin
Old Jun 12, 2008 | 03:13 PM
75_CorvCoupe's Avatar
75_CorvCoupe
Navigator
Always check your tranny fluid with the engine running.
Old Jun 12, 2008 | 03:22 PM
Wuttin's Avatar
Wuttin
...with the engine hot, car on a level surface, after having gone up and down through the gears. Then repeat and check it again.
Old Jun 12, 2008 | 03:31 PM
dodge_ss/t's Avatar
dodge_ss/t
tell who ever did the work that the line on the dipstick is a limit not a suggestion
Old Jun 13, 2008 | 12:04 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
It could now be leaking where the dip-stick tube enters the tranny case from being overfilled.
Old Jun 13, 2008 | 01:23 AM
sly vette's Avatar
sly vette
Good place for a leak if it is overfilled.
Aren't there instructions on the dipstick on how to check the fluid. I know there used to be.
Any way...car running on level ground and I believe it should be in neutral.
Old Jun 13, 2008 | 08:47 AM
Vampyre's Avatar
Vampyre
Should it be set to Neutral or Park?
Old Jun 13, 2008 | 09:50 AM
CA-Legal-Vette
Park, but more for safety than any difference in the resulting level.
Some of the older GMs used to put in the owner's manual that you had to check the level in gear with brakes applied. You can just imagine the outcome of that recommendation. I think their lawyers made them change that one.
Old Jun 13, 2008 | 10:43 PM
my 76 ray's Avatar
my 76 ray
It could also be the seal where the shifter linkage enters the transmission case.
To Overfilled tranny fluid
