Alternator pulley
Old Jun 21, 2008 | 08:07 PM
dmayhew's Avatar
dmayhew
Default Alternator pulley
I have a 1971 LT-1 , but the alternator was replaced at some time in the past with a standard Auro Zone unit.
The pully is not a deep groove and I fear it may be thrown off.
All other pullies are deep.
Is it possible to buy a deep pulley that will fit the shaft on my standard alternator?
My hope is that the shaft and hole in pullies are all universal and if I find the correct belt side configuration that it will be a easy swap out.
David
Old Jun 21, 2008 | 11:39 PM
Durango_Boy's Avatar
Durango_Boy
You are correct, the Chevy alternators all shared the same shaft size, even up into the '90's, so if you find a GM deep groove it'll prolly fit great.
Old Jun 22, 2008 | 12:12 AM
Ironcross's Avatar
Ironcross
Most Ford pulleys are wider than GM`s and the shaft is the sam size. You can inpact a Ford on your GM alternator rotor....
Old Jun 22, 2008 | 10:22 AM
dmayhew's Avatar
dmayhew
Thanks Durango Boy and Iron Cross
This is a big help
The CF proves to be a great asset once again.
David
Old Jun 22, 2008 | 01:25 PM
MN-Brent's Avatar
MN-Brent
For what its worth, when I was new to my Vette, my original alternator failed, so I thought it did, and without thinking, I traded it in on a core at a local Checker Auto store for a rebuild. It was only after I got the new unit installed did I realize I gave up my deep groove pulley, which was a few days later.
Turned out it wasnt even the alternator, but the exciter line coming from the idiot light that was open.
But since then- (summer 2002) I been running the non deep groove alternator and have never thrown the belt.
Making the switch up to a CS144 this year and it also has the non deep groove V-pulley.
B....
To Alternator pulley
