Anybody worked out how many gallons are still in their C3's tank when the gas gauge is on "E"?
Yesterday I was on a long run between gas stations and well and truly hit "E". I thought I was going to be stranded on the side of the road at any minute, however, when I finally did get to a gas station I was surprised that it didn't take a 20 gallon fill.
Just had that discussion today while driving my 71 home from Bloomington Gold in St Charles, Illinois. I was on about 1/8 tank and when I filled it up it took only 12.9 gallons===leaving 7 gallons left. I think the only way to really know is watch you mileage and use the odometer--run it as low as possible after E once to see for our car. Does anyone know is the gas tank outlet on the bottom on the tank or one inch off the bottom or what--that would help.
I should have mentionerd that mine is a 454ci 1970. According to the owner's manual the standard tank is 20 gallons and there was an RPO coded NA-9 for a 17 gallon tank, although why anybody would request a smaller gas tank on an original 454 is beyond me.
So, I'm assuming that mine is the standard 20 gallon tank. After running on "E" for a good while, it took only 15.25 gallons to fill again, which means that I have around 5 gallons, or about 25% of the tank remaining when the needle is on "E".
On the other hand, if by chance the original owner specified a 17 gallon tank, then I have less than 2 gallons left on "E". (I don't have the build sheet. Well I do but it's totally unreadable.)
I never let mine go past 1/4. I am curious if you drive until it runs out and have a gallon jug, drive to a gas station and fill up. will this method tell you the tanks real size as sold?
All I know is that by the time my car gets to 1/4, it's time to start hunting for a gas station fast. Right after I bought it, it was getting pretty low, so I looked in my gas tank to check since I didn't know if the gauge worked well. It appeared to have at least a couple inches of gas so I figured I was ok.... I went 6 miles and it was dry. Not a fun day.
According to the Corvette Black Book, my 80 has a massive 23.7 gallon tank, just like the 78, 81 and 82. I've gone down to E on a couple of occassions, and my maximum fill has been 18-19gals, so I figure I have ATLEAST 4 gals, or 56 miles as a cushion. BTW, the 79 is listed as having an even larger 24 gal tank- only topped by the super rare 63-67's with the optional 36 gal tank.
My '79 should have the 24 gallon tank, but my gauge also reads empty after about 60 litres down. This means I should have about 30 litres left when it reads empty, but I haven't tried it out yet because I fear my tank will contain sludges and/or other stuff that will clog up the fuel lines/filters/carb. How real is this threat and can one somehow verify how dirty the tank really is?
Here's what the 1970 owner's manual says. Note that it claims the 20 gallon tank is "standard" and the 17 gallon tank is optional.
NA9 is California Emissions so those cars must have used the smaller 71-up tank due to the vent and charcoal cannister system, so not really an optional fuel tank. The 70 Federal Emissions I guess used the same 20 gallon tank as used in 68 and 69. I wonder though how the 70 Federal tank vents? Do you have a sealed or vented fuel tank cap?
I got down to E about 2 mi from the gas station in the 71 (that last 1/4 went uber fast!). It filled up w/ about 14 gal. So, how many gal is my tank? I have a feeling I had more left than what I thought.
When I first got my '70 I would fill up often because I didn't trust the gauge. Then I took a flashlight and looked into the tank to see the "Seam" in the back of the tank - this meant about 1/2 full. When I get to about 1/4 I fill up with about 12 gallons - meaning I still have 8 gallons left in a 20 gal tank. It is non vented and when tank is only 1/4 full there is a lot of pressure when taking the cap off - hissing at me!
I have a locking fuel tank cap that is vented.
I do know that the original owner of my car lived in Arizona, so it shoudn't have been affected by Californian requirements in 1970.
However, I'm starting to think that I may have a 17 gallon tank.
Take a 5 gallon tank fill it go out on the highway and see when it runs out unless you think you may have any sediment in there .In which case I would not run it below a quarter. I'm sure that beast sucks up 1 or 2 gallons pretty quick.
