kick panel
Old Jul 3, 2008 | 10:27 AM
Toms82's Avatar
Toms82
Default kick panel
Hi,
One of the kick panels on my 82 has a crack in it. What can be used to repair it?
Thanks,
Tom
Old Jul 3, 2008 | 10:32 AM
7T1vette's Avatar
7T1vette
JB Weld putty-stick epoxy. Put some on the inside of the panel to back up the crack. Then re-dye the panel. If you haven't lost any material at the edges of the crack and you re-align it when you put on the epoxy, it should be fine.
Old Jul 3, 2008 | 11:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If it's a closed crack, superglue or TenaxR7 will hold it.
To kick panel
