C3 luggage rack load
Old Jul 7, 2008 | 03:27 PM
miked76's Avatar
miked76
Default C3 luggage rack load
I have eight post luggage rack on my 76. I have a pop up canopy/tent, weighs 35 pounds. Anyone know if this is alright to carry on the luggage rack? I cannot find a load limit in any literature, and want to bring canopy to shows.
Old Jul 7, 2008 | 04:04 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Old Jul 7, 2008 | 04:13 PM
tacflex's Avatar
tacflex
Cruising
I wouldn't think it would be a problem. 35 lbs isn't really that much. The t tops are probably around 20. As long as the weight is evenly distributed. Do a test, put the canopy on it and see if it bows. If it doesn't, you're good to go.
Old Jul 7, 2008 | 04:47 PM
rayluka's Avatar
rayluka
This isnt Gospel, but I was told 50lbs MAX. I don't know where the person that told me received this information
Old Jul 7, 2008 | 04:54 PM
LoneStar26047's Avatar
LoneStar26047
I would also worry about wind drag. If it is one of those pop-up canopies with a lot of canvas on one end then it could provide a lot of wind resistance on one side. Might not be a good thing above 50mph.
Old Jul 8, 2008 | 01:35 PM
miked76's Avatar
miked76
thanks all. the tent is in a zippered bag, wind is not an issue. I have put mirrored t-tops on rack for long rides, no problems.
Old Jul 8, 2008 | 01:48 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Thanks for the info, guys. I found that putting anything on mine interferes with the rear view. My car only has the driver door mirror so blocking the rearview made for some anxious moments and lots of head turning to keep the blind spot in check.
I've since bought a matching passenger door mirror to mount up if I wish to carry the t-tops in their carry bag back there again. It's got to help feedback who's off the rr fender before any lane changes or when backing up.
Old Jul 8, 2008 | 03:00 PM
smon's Avatar
smon
there was a thread about this not too long ago. a member on here posted pics of his luggage rack with a deer on there. I think you hsould be fine with just 35 lbs.
Sean
Old Jul 8, 2008 | 03:05 PM
7T1vette's Avatar
7T1vette
I've put that amount on my 6-post rack many times. If you were going over rough terrain (in my Corvette?? not!), you might put more stress on it; but normal road travel shouldn't be a problem.
Old Jul 8, 2008 | 09:07 PM
AimHigh's Avatar
AimHigh
not so much the load as the drag. I replaced mine the other day and was amazed at how simple it is on there, couple of expansion inserts and then screw it down. NOT the best system for ANY kind of load or abuse. Like another member mentioned it is more for decoration and maybe a little beer too.
Old Jul 8, 2008 | 09:59 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
You will get a mix of answers on this one, but....Yes....go ahead. In 1979.... ....my wife's daily driver was a 70 LT1 Coupe. We used to load that rack up with camping stuff. It went camping in N. Ga many weekends. Sure wish I still had that one...and the 69 ...
Old Jul 9, 2008 | 07:59 PM
Binnie77's Avatar
Binnie77
According to the GM Instruction sheet that came with the rack, it says 50 lbs maximum. You can view a copy of the sheet here:
'77 Documentation
Old Jul 10, 2008 | 11:44 AM
miked76's Avatar
miked76
thanks, you are truly the man. I have all the original documentation for my 76. Strange, even the rips in the sheets are in the same place. Must have been that old assembly line mentality that everything is the same on the line, including glue.
Best thing about looking at my Chevrolet brochure is remembering that they actually made a Monza.
Old Jul 10, 2008 | 06:01 PM
BritewhiteC3's Avatar
BritewhiteC3
'77 Documentation
Great Post as usual from Binnie
Old Jul 11, 2008 | 09:34 AM
Dustup7T2's Avatar
Dustup7T2
Miked76 - sent you a PM. FYI.
To C3 luggage rack load
