front springs
Old Jul 7, 2008 | 10:09 PM
namvet6869's Avatar
namvet6869
Default front springs
just did a front end suspension rebuild. after putting the coil springs in i noticed i didnt get them installed to the stop the correct distance. one is just about right while the other is about 3/4 inch from the stop. will this cause a problem???????? the original spacing was not even close to the stop. thanks, namvet 6869
Old Jul 7, 2008 | 10:24 PM
MN-Brent's Avatar
MN-Brent
If you have the GM helms manual, it shows the correct seating distance in the top perch. Its something like .318 inch.
If you dont get it set in at the right distance from the upper pocket, you'll have ride height issues, but I think thats about it.
B....
Old Jul 7, 2008 | 10:26 PM
bj1k's Avatar
bj1k
Won't hurt a thing. Actually there is a drain hole at the stop that shouldn't be covered.
To front springs
