No start after driving a while.
Old Jul 10, 2008 | 05:25 PM
vwcorvette's Avatar
vwcorvette
Default No start after driving a while.
So I've seen numerous threads of a similar vein. So I read the search outcomes, and did some investigation and correction. Guess what? Still having problems.
Thought it was heat soak. Tried a shield. No Change. Then, duh, if it were heat soak I wouldn't be starting it with my trusty Snap-on large screwdriver. Shhh, don't tell!
Anyway, I replaced the fusible links as well. No go.
Finally, I checked for a signal at the s-terminal when it wouldn't start. None.
There is a relay on top of the A/C box in the firewall. Is it some sort of interlock relay? Thought I saw someone mention that in one of the posts, but am tired of doing the same search over and over.
Am hoping it's not in the column. Don't want to mess there. What color are the wires if in fact that is the relay I'm thinking about?
1975 L48 Auto.
Thanks,
George
Old Jul 10, 2008 | 05:55 PM
...Roger...'s Avatar
...Roger...
Yes it is an interlock-just jumper it.
Old Jul 10, 2008 | 05:58 PM
Gordonm's Avatar
Gordonm
Yes it would start if it was heat soak with the trusty screw driver. I used to carry a large screw driver with me in the early 80s on my 70 Camaro for just that reason. Got me started many a late night with this. The purple wire from the ignition switch goes through the neutral switch on the auto cars and the clutch switch on manual cars. It should go right from there to the starter. On all my cars there has not been any relay and I'm not aware of any on the 75 cars but Bubba may have gotten to yours.
Shows what I know about 75 cars. What is the interlock for?
Old Jul 10, 2008 | 06:04 PM
...Roger...
Makes you put the seat belt on.
Old Jul 10, 2008 | 07:48 PM
Gordonm's Avatar
Gordonm
Ok I remember them now. Kind of a stupid feature. It did not last to long as I remember.
Old Jul 10, 2008 | 10:16 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
I thought that interlock relay was for '74 only!
Old Jul 10, 2008 | 10:17 PM
...Roger...
Thank the Corvette gods for that !!!!
Old Jul 11, 2008 | 03:19 PM
vwcorvette's Avatar
vwcorvette
Thanks all!
Gonna replace the relay. Or maybe just bypass it as you say. Any negatives to bypassing? I'm not with the NCRS police!
George
To No start after driving a while.
