Headlight Actuator Color
Old Jul 17, 2008 | 11:52 AM
trainmankjm's Avatar
trainmankjm
Default Headlight Actuator Color
Planning to rebuild my headlight actuators. Would like to paint them, what color would be close to the original? Also need recommendation on vendor/supplier.
Old Jul 17, 2008 | 12:53 PM
GD70's Avatar
GD70
They weren't painted. Just the natural gold metal color.
All the vendors sell them. Just check if they are imported chinese junk, or USA made.
Old Jul 17, 2008 | 01:56 PM
LOTSARED's Avatar
LOTSARED
Default Cad plated
That orginal "goldish" color is cad plating. They, like some other bits (brake master cylinder cover, for example) were cad plated originally.
Most restoration shops can do this for you. Or some resto supply catalogs sell a multi-step paint process that results in a similar color/appearance.
If all that's too much hassle, probably the best single step paint would be some sort of light gold color in a satin finish.
Old Jul 17, 2008 | 05:28 PM
Alan 71's Avatar
Alan 71
They were plated originally as others have said.
If you're going to paint them.... use VERY thin coats. Silver first, then some gold, dusted on, then some copper in some areas, some orange in some areas, finally a very light dusting of blue in 1 or 2 areas. All the coats except the silver should be so light that you can see the other tones through the color you're putting on. This is a lot of trouble but makes the cans look pretty realistic.
Regards,
Alan
Old Jul 19, 2008 | 03:01 PM
trainmankjm
Thanks for the info!!
Old Jul 19, 2008 | 11:52 PM
eastltd's Avatar
eastltd
Regards,
Alan
I've tried it and Alan is right. It can be made to look very close.
Here's a shot of the factory coating. I couldn't get the old ones nice enough, so I bought new.
Old Jul 20, 2008 | 12:04 AM
62fever's Avatar
62fever
Nice looking actuator. You rebuilding that car in a bar?
To Headlight Actuator Color
