LONG cranking before start-up
Old Jul 19, 2008 | 07:29 PM
randommj's Avatar
randommj
Default LONG cranking before start-up
Ive got to hold the key to "start" for a LOOOONG time before the car will start, Ill be soon pulling the carb off to install the "quadrajet diaper" and Im leaning twards drilling them out, tapping it nd installing permanate ones
1. how do I do this? (drill, tap and replace plugs)
2. could there be some other cause for my problem?
Miles
Old Jul 19, 2008 | 07:56 PM
Duke94's Avatar
Duke94
This has come up many times and the answer aleways seem to be the gas . With the Q-jet carb they are more prone to evaperation. I'm sure others will chime in on this one. The Edelbrock carb I used for a while always started right up. Put the Q-jet back on and it takes a bit of cranking.
Old Jul 19, 2008 | 08:09 PM
onaqwst's Avatar
onaqwst
i got a carb from lars and installed it..... cranked right up......q-jet
makes sure your battery terminals/ground is clean
Old Jul 19, 2008 | 08:24 PM
Theiskell's Avatar
Theiskell
Does it do it when hot also or only when cold?
Old Jul 19, 2008 | 08:40 PM
randommj's Avatar
randommj
only when (really) cold, like after setting over night, it stars right up after sitting for 10 hours at work, which is what Im thinking my fewl bowl is emptying out somewhere
Miles
Old Jul 19, 2008 | 08:49 PM
Theiskell's Avatar
Theiskell
I would go with a gas problem also. Do you see any fuel leaking out of the carb?
Old Jul 19, 2008 | 09:04 PM
randommj's Avatar
randommj
no feul leaking, I just went out to check, I drove it today from 5-530 and its now 8, and about 88 degrees out, the vette has ben running about 10-15 degrees hotter than before and I still needed to use towels to lift my air cleaner off its so hot, shouldent it be cooled by now? maby my fuel is evaporating rather than leaking from the plugs
Miles
Old Jul 19, 2008 | 09:26 PM
1stC3Vette's Avatar
1stC3Vette
I also have a '72 and had a similar problem. In the end, I had the carb rebuilt and it fires up hot or cold with no problems.
If you are concerned about fuel evaporation, before starting the car, remove the air cleaner lid and hand actuate the accelerator pump. If you see fuel squirting in, this is not your problem.
What is your timing set up at? Have you recently tuned the car? Are you running points and have you replaced your wires lately?
Good luck,
Dino
Old Jul 19, 2008 | 09:32 PM
randommj's Avatar
randommj
Good luck,
Dino
will do tomorow!
Ive got new wires, gapped my points and replaced my plugs about a year ago, timing not so sure on...butI didnt have this problem 2 weeks ago before the carb rebuild (I did myslef, not professional)
Miles
Old Jul 19, 2008 | 09:59 PM
Theiskell's Avatar
Theiskell
you may have your carb adjusted to a lean condition. That would explain the running hotter.
Old Jul 19, 2008 | 10:04 PM
randommj's Avatar
randommj
how will I know what the adjustments are "just right"? I seated the metering jets and turned them back 3 turns each, I assume I unscrew them more but should I go in 1/4 turn incroments?
Miles
Old Jul 19, 2008 | 10:17 PM
Theiskell's Avatar
Theiskell
I would not want to give you bad information on this. I'm not much of a carb guy Hopefully someone more experienced with the Q jet will chime in to answer your question.
Old Jul 20, 2008 | 12:47 PM
randommj's Avatar
randommj
bump, how do I know when Im not running too rich or lean?
Ill prob. try it today, when I remove the carb to drill the plugs would it be OK to just leave my metering jets in the position they are in, or would I have to start from sctratch?
also I just went out and oushed my accelerator pump down and NO fuel was being squirted, so Im assuming my fuel is evaporating, what do I do about this?
Miles
Old Jul 20, 2008 | 12:51 PM
BKbroiler's Avatar
BKbroiler
How about the choke? Even in warm weather a choke is needed for quick start of a cold engine. I have an electric choke on my Qjet. Just pump the gas to set the choke and fire it up.
Old Jul 20, 2008 | 01:19 PM
Theiskell's Avatar
Theiskell
Aain no carb guy here, but how would it evaporate without a leak some where?
As for the choke..... I have no choke on my 383 and it starts hot or cold no problem
Old Jul 20, 2008 | 01:22 PM
randommj's Avatar
randommj
I set the choke everytime I start it up, Im just thinking there is NO fuel in my fuel bowl, how its getting out Im not quite sure: evaporating, leaking out from the two plugs, or just syphoning back into the tank
Originally Posted by DWncchs
Siphoning back to the tank can also empty bowls but my point was "if" the plugs were leaking he would have to fix them.If you do end up with an empty bowl after sitting all night you just have to determine. what is causing it.One way to eliminate the siphoning back to the tank is to clamp the rubber fuel lines at the pump and if its still emptying its not siphoning.
which rubber hoses are the ones mentiones in the quote? Ill plug them tonight to check
Miles
Old Jul 20, 2008 | 02:32 PM
Theiskell's Avatar
Theiskell
Miles
where your hard lines from the fuel tank change over to rubber flex line to hook to your fuel pump.
EDIT>>No need to "plug" just clamp it off with a pair of vice grips
To LONG cranking before start-up
Old Jul 20, 2008 | 02:44 PM
randommj's Avatar
randommj
from the back of the carb or the front? or does it matter?
Miles
Old Jul 20, 2008 | 03:15 PM
Theiskell's Avatar
Theiskell
Miles
I’m not sure how your fuel lines are ran. I ran hard line all the way up to my carburetor so the only place I could clamp off a line is where the flex line goes into the fuel pump. If you have rubber line in other places I would say start at the carb and work back to the fuel pump a section at a time. I don’t know of a quick way to do it…. just clamp off a section overnight and see if you have fuel in the bowl the next morning if you do, work back until you don’t and that will be where your problem is.
Old Jul 20, 2008 | 05:22 PM
randommj's Avatar
randommj
Ill crimp it off after a ride it it today
What kind of epoxy should I use on the plugs (after drilling and taping)? and how will I know if Im running just right on my fuel mixture?
Thanks so much everyone for all the help so far! every responce hase been extremely helpfull
Miles
