c3 body mounts
Old Jul 20, 2008 | 06:16 PM
gforce Vette's Avatar
gforce Vette
Default c3 body mounts
I'm removing the body from a 77. Got all th bolts out with no problem except the rear ones. It apears I will have to replace the body mounts at the rear,bolts wrung off and badly rusted.
Does anyone know where I can get these mounts? They are riveted to the body.
Old Jul 20, 2008 | 06:27 PM
Steve's74's Avatar
Steve's74
Most any Corvette supplier will have them. Zip, Mid America, etc.
Steve
Old Jul 20, 2008 | 08:29 PM
gforce Vette
Thanks, I'll look in their catalog.
Old Jul 21, 2008 | 08:08 AM
??????'s Avatar
I know exactly what you mean. Here is my 77.
As you can tell, One bolt broke off, and the other I had to cut in half to get the body off. I am facing the same issue. You are not alone. I will have to remove mine off the body to do the repair.
Good Luck with yours,
Grant
Old Jul 25, 2008 | 10:10 AM
joe@zip's Avatar
joe@zip
Platinum Supporting Vendor
Give us a call or order online.
68-82 Corvette Body Mounts
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
Old Jul 25, 2008 | 11:22 AM
72LS1Vette's Avatar
72LS1Vette
The part that you see in the above post is a body mount reinforcement. The ones on my 72 had rotted and I just received new ones from Zip last week. If your reinforcements aren't rusted there is no need to replace those, provided the bolt comes out easily. There is a caged nut inside the car that will have to be dealt with if the bolt is frozen. I believe the reinforcement will need to be removed if the caged nut has to be replaced since the cage rivets are covered by the reinforcement. The reinforcement rivets are aluminum and grind off very quickly so it's not hard to get the reinforcements off.
Rick B.
Old Jul 25, 2008 | 08:08 PM
Red 69's Avatar
Red 69
Do a search and you will find plenty of information on replacing those parts.
Old Jul 25, 2008 | 11:03 PM
eastltd's Avatar
eastltd
Here's a shot of the #3 & #4 mounts after the replacement that may help you.
Old Jul 26, 2008 | 03:20 AM
stavanger's Avatar
stavanger
Body mount replacement
Old Jul 26, 2008 | 05:42 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
The hard part is resisting "the while I am it" syndrome. I started with the body mounts and have since transitioned into a full restoration. Good luck!
To c3 body mounts
