I allway place a hydraulic jack *just* in contact with the frame, so if the car moves for some reason, the jack will move with it and take the load, if the stands tip over.
This is good information. Could you help me with the pad though, not sure what pad you are describing, are you talking about the pad on my lift? Thanks for your help.
David
Go to a Medical Supply store and ask for the pads that go on top of a pair of crutches. They work great.
I had the car on jack stands 15 years ago. Two jack stands in front. Rear tires in contact with the ground in the rear. My dad and I were working under the car and applying a lot of force upward. We actually lifted the car up enough and to the side and the car fell off the jack stands. I was under the car and he was half under the car. I realized it was moving and pushed out from under the car in a fashion that took him with me. The car crushed a headlight cover and that was it.
So lessons I learned were:
1) have a back-up "jack stand" so you don't get crushed. An old rim or a 6 x 6 with a couple of 2x6s nailed to it work great. (nothing mechanical there to fail).
2) know what you are doing on the car and anticipate the outcomes of your efforts. I've had bolts frozen on the chassis, and lifted the car off of a corner with good cheater bar. (This is more prevalent as you remove a lot of things, because the car is lighter). Somewhere, I've seen a photo of someone's car that fell off of a lift.
I put the jackstand on the side in which I am working and bring it to just within pressure as a backup.
I also don't work on the car unless I have a spotter present, never alone. My spotter is out picking up parts for me today so I will be under the car this afternoon taking off the patriot pipes. I will then bring the car back to the ground for some internal work over the weekend. Should be in much better shape by the end of the weekend. Can't wait.
Thanks again.
David
And I understand this one. Upward pressure would be capable of pushing the car up and off the stands. My work will be disconnecting the exhaust pipe running from the manifold to the Patriot Pipes on the car. When the bolts are off and I can remove the pipes I will put the car back down on the ground. Sounds like a plan.
Thanks again.
David
I put the jackstand on the side in which I am working and bring it to just within pressure as a backup. Attachment 47626882
Thanks again.
David
you'll be fine, but as a side note, the jack I use is one of those $20 cheapos with a removable handle. I was thinking this is what you had. What worries me about you're set up, is handle sticking up there. If you can remove it duing work, do, as someone could come along and trip, pull down on the handle, move the jack up and upset the car on the stands. cheapos will work just fine and are around 20 at autozone.
How safe is it to lift the car and place rims under the tires?
I have a set of spare aluminum rims from my old 78. I always felt safer to place the car on the rims laid sideways.
Thoughts?
I always have an extra set of mounted wheels laying around and I slid them under the car just as fail safe insurance. If the car falls they shuold at least keep you from getting squashed. I also have three floor jacks and I'll slip one or two of them under the car also.
My most nervous moments have been laying under the car, torqueing up the pitman arm nut. I needs something like 140 ft-lbs. Even using this much torque with a nearly three foot torque wrench always makes me fear that I'm going to twist the car off of the jacks! I know, it doesn't seem like I could actually budge the car, but I still feel a lot of anxiety.
Another thing I do nowadays.......keep a cordless or cell phone under the car with me when working alone. I have heard stories of guys getting pinned uninjured under the car. If you at least have the phone with you you may have an out!!!!!
If working alone I would agree with you, makes good sense. For me I will never get under the car without a buddy or spotter on hand. Just makes good sense to have emergency aid on site before you need them. Great advice for those willing to go it alone though.
David
Actually you make a good point. My son was with me when we went under the car and he was at the point of the jack while I was under the car. The handle can easily be removed when not in use, but in our case I wanted him there if he needed to quickly re-raise the car for some reason. Thanks for the tip, good points.
Thank you goes out to all who have written on this. I have completed my work under the car and the car is safely back down on the ground. For the record I jacked one side first, then the other, and it worked out well. Also for the record, I got a crack in the front of the car by leaving the nose hanging out there, so from now on I would recoommend two jack stands up front, and two in front of the back wheels. Now back on the groudn the flex crack is all but invisible, but I know it is there.
We did it as a team, did it safely, and did it quickly to get it up, get in, get out, get her back down. I couldn't have done it without your help.
Yea, Never jack the car at the cross member, not designed for it and it will dent in. safest way to work on a car is two jack stands in front, rear wheels on the ground and E-brake locked in tight, roller floor jack in contact with the frame a bit, safest way. good luck, and happy 'Vette work. Chris.
My cross member is dented, any idea how to get it out?
