dynamat vs reflectix?
is a better heat and noise barrier.
However those that are watching their pennies feel the Reflectix, does nearly as good of job, at a much lower cost.
( and you can buy the Reflex at lowes/Home Depot )
a small 25x2ft. roll will cover all your front cabin, but not the rear cargo area, buy a second roll if you wish to do that area.
good Luck 69VETT
They are two different products for two entirely different purposes. They are used together...not one instead of the other.
Dynamat is a sound deadening material and Reflectix is a heat barrier. They have completely different properties so Dynamat won't guard against heat and Reflectix won't guard against vibrations.
The Dynamat or comparable sound deadener would go down first on the bare floors and panels of the cabin. The Reflectix goes next, followed by carpet.
I do agree with Hamad, I would like to stop it before it ever enters the car from underneath but too many other projects in front of that one for now.
Dynomat does have a heat insulator fyi.
Here is my perspective: I bought a heat/sound insulator mat from a company on here. I can't remember the name off of the top of my head. I installed it in my 2000 cpe. I used the aluminum tape to adhere the product, no glue (thankfully). As far as a heat barrier it seems to be pretty effective. I live in South FL, and am running long tube headers in that car. the heat has been reduced, but I can still feel it. (someone mentioned stopping the heat before getting in the car...) The problem with the product is fit. With that mat all over the cabin... I had to remove some of the factory insulation in certain areas, and my subwoofer box doesn't fit right in the trunk. As far as sound deadening, I didn't notice any. I still wear earplugs on the highway.
My current resto product is getting lizard skin. I'm actually prepping it right now. (Yes you can make your own). I went with the pre-made product. It will be some time before I can tell you the results. I am spraying the ceramic heat barrier material under the car, in the tunnel and where the pipes will run. (I am also replacing the factory heat shielding with reproduction products). On the interior I will use the sound deadening product. I will spray both products and do the accompanying prep. It will be a while before I can give you the feedback on the product.
Note: I have not used a decibel meter to determine sound reduction.
If so, can it be pulled up easily to replace?
I need to do this job but still have not decided which product to use.
http://forums.corvetteforum.com/show....php?t=2066084
To the OP it depends what you're trying to accomplish. I needed 13 2' x 3' sheets of Dynamat ($$$) and one standard roll of Reflectix (cheap) to do the whole interior (minus the doors) of my 79.
They work beautifully together, both heat and sound clearly improved. I expect they would work on their target problems just as well if used independently, although Dynamat does add some heat block. Tedious as anything, but glad it was done.
Best of luck, Steve
I recommend against it for the thickness. Or use it in areas where it won't effect fit and finish.
I know people have had good experience, but I find it annoying when panels bulge and don't fit well.
One note if you go the lizard skin or "micro-spheres" route. Wear a respirator when handling the micro-spheres if making the home version. There is a risk of silicosis. Also, I'm not sure if Hy Tech is still in business, they never responded to my emails. http://www.hytechsales.com/
Google it, there is a lot of info on the micro-sphere thing.
As a side note. People should consider wearing a respirator when doing any type of sand/ media blasting, fiber glass sanding, and whenever they are removing particulate (dust) type stuff from these cars.
It's not even close to being the same as Dynamat. The FrostKing HVAC stuff is a foam rubber that is foil backed. As you mentioned, it is intended to insulate through contact (ie non-radiant), not sound deaden. With that, it doesn't have the same efficiency to reject radiant heat that Reflectix does (which is amazingly efficient).
http://www.frostking.com/Lowes/FoamF...Insulation.htm
Again, what's the goal...if you're looking to block the radiant heat sneaking in through the floor/firewall/tranny tunnel Reflectix is a cheap and easy to use option. The foam will likely work, but nowhere near as well. If you're looking to block sound the foam is not the answer.
In many ways sound deadening is a function of holding things together. Dynamat extreme is a dense butyl rubber with a foil face, not a loose foam rubber like the FrostKing stuff. It is thin but incredibly sticky and stretchy. It works by stopping parts vibrating, then distributing any residual vibrations over a large area to make them inconsequential. The cheap foam will most likely not deaden sound because it will not eliminate or distribute the vibrations in the same way.
Dynamt is crazy expensive, even the best deals. If you're looking to block sound it's top notch, but there are other cheaper products out there that are reasonable, cheaper substitutes. The specs are not as good as Dynamat but they are designed to sound deaden. I don't expect the FrostKing stuff will do the job though...minimum would be FatMat or some semi-equivalent butyl prodcut.
As far as the heat block I highly recommned Reflectix. Cheap and easy.
Go for it, Steve
