"EZ fit" flex bumpers
Old Jul 23, 2008 | 01:41 PM
johnmb's Avatar
johnmb
Default "EZ fit" flex bumpers
I note that there's basically 3 types of replacement bumpers...the original urethane, the rigid fiberglass, and some in - between "flex fit" or "easy fit" version.
Does anyone have any experience good or bad with these semi-flex units, before I order a front one for my 74?
John
Old Jul 23, 2008 | 02:21 PM
Scott Marzahl's Avatar
Scott Marzahl
Are you replacing a rear or front. The rears tend to fit better than the fronts. If you want an EASY replacement, spend the money on the OEM urethane type. I have about 6 hours into fitting a new front fiberglass one but every car has a different fit and you might get lucky.
The flex fits do not really flex either, not enough to really make a difference anyway.
Old Jul 23, 2008 | 03:41 PM
justaguy10825's Avatar
justaguy10825
I guess I do not understand the whole "Flex" concept where it pertains to anything with paint on it. I would think that anytime a painted item "Flexes" you end up with cracks in your paint??????? When I bought my 78 it had the urathane bumpers and they both needed to be replaced due to being warped... I decided to go with fiberglass & did a bunch of re-shaping to make them fit (especially the front)... I think it was worth the extra effort & I am not afraid of bumping into them and messing up my paint...
Old Jul 23, 2008 | 03:55 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Cannot speak for anything else .I have the Flex Fit from Toledo pro Glass and I think they are great ,I did the front and the back I havent even Painted them (Hence The Vader Vette) my car is silver with black bumpers and I even painted the spoiler it looks cool Sometime I will paint the Whole car silver But for now ,Silver and black. I had little fit problems but nothing that a little time did not take care of I used A heat gun to get the to surfaces to mate correctly mine look like factory,I did clean up the car I used the little brush and the car color it looks great.
Old Jul 23, 2008 | 06:28 PM
johnmb's Avatar
johnmb
I'm doing the front one.
I'm just curious if there's any substantial difference...
Old Jul 23, 2008 | 09:07 PM
redwingvette's Avatar
redwingvette
I did the front on my 73. It did take a little work to get the flex-fit to work. Mostly on the right side for some reason.
Bumper
Old Jul 23, 2008 | 09:53 PM
trw's Avatar
trw
What do you do to fit the flex?
Sand/Grind the bumper or fill the fenders?
Old Jul 24, 2008 | 06:53 AM
crazywelder's Avatar
crazywelder
You never add filler to the body to make a bumper fit. You sand the back of the bumper until you get the best fit, then add filler to the backside of the bumper to finish the match the body.
Flex bumpers do not flex enough in the right places to make them advantageous. If the the flex bumper does not fit, return it and get a standard fiberglass bumper because the fitting process will be the same. It does not make sense to apply filler to a somewhat flexible part. The flex bumper will flex and buckle a little as you tighten it against the body, the filler you add does not flex.
Old Jul 24, 2008 | 10:27 AM
08Roadster's Avatar
08Roadster
Did the front and back on my '75 vert with the fiberglass ones - easy job. Fit was good with minimal effort. Paint matched perfect - would definitely recommend going that route unless you are planning on showing the car and need it to be completely stock.
Old Jul 24, 2008 | 12:33 PM
TopGunn's Avatar
TopGunn
I did the front on my 75 with a fiberglass, I had a flex fiberglass but sent it back because it arrived damaged. I really didn't see too much difference between the flex and the fiberglass as far as flex was concerned.
BUT....it was the worse job I've ever done on a car getting that POS bumper to fit!! I had to move the brackets way up and grind the hell out of the rubber crash cushion behind the bumper to get things to line up. It was definately not a fun job!
To "EZ fit" flex bumpers
