My engine
Old Jul 29, 2008 | 07:57 PM
Rickster - C3 69's Avatar
Rickster - C3 69
Default My engine
Well DB has me started on the radio. Now time to learn about my engine. Here it is, not a pretty as some of yours. But maybe in time. I know almost nothing about engines so feel free to educate me on anything you see. I know from my mechanic that it runs "rich" and moves a lot of gas.
Old Jul 29, 2008 | 08:02 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
I Don't see anything bad, A few aftermarket items Distributor, air cleaner, and pcv valve hose missing I would get an engine repair book on your year and a chevy sbc rebuild book, I think this will be a good start into this vette madness
Old Jul 29, 2008 | 08:28 PM
Rickster - C3 69
Are the books for sale on the forum here okay? I'll do a search online as well but I quickly looked at the available manuals/references for sale here. If anyone recommends them let me know.
BTW - this forum is awesome. You guys rock. I think the best part is when someone gets to the next stage of their rebuild or finishes something and gets like 20 compliments from the forum crew. How could you not want to finish your project?
See you in Carlisle I hope
Old Jul 29, 2008 | 09:14 PM
Durango_Boy's Avatar
Durango_Boy
Looks good. A few things as mentioned...the PCV valve. Get your mechanic to hook it up or tackle it yourself. It just needs to connect to a vacuum port on the carb or the tree on the back of the manifold.
Make sure you have the PCV valve on the driver's side and a breather on the passenger side, and plug any other holes in the valve covers.
I see there is a tiny pool of oil in one of the valleys next to the intake bolts. That usually means sealant was not used when the intake was bolted down.
Simply unbolt them all, add sealant, and re-torque them.
Finally, and very important, get rid of that flex fan and spacer. Replace it with a stock style clutch and 7 blade fan...or an electric. Those flex fans have a reputation for loosing blades which punch holes in hoods and fenders.
Good luck,
Matt
Old Jul 29, 2008 | 09:26 PM
400hp427vette
St. Jude Donor '09
If you get books from the forum here. They will be the ones you are looking for. If you buy from Ebay etc.... You are taking chances as to are the books really the ones that will teach you what you want to learn.
Old Jul 29, 2008 | 09:35 PM
Theiskell's Avatar
Theiskell
I can’t believe no one has jumped on him over the fuel filter.
Edit>>> That looks like a Big block fan shroud....My original small block fan shroud looks diffrent?
Old Jul 29, 2008 | 09:36 PM
Rickster - C3 69
thanks. I'll need to do some research (find some good manuals) to do some of that work.
The pool of oil is the one under the air filter correct? What sealant brand is recommended (I assume I can buy at any auto supply place)?
I'll definitely look into the fan replacement. Thanks for that good bit of info.
Also - does anyone know why the tach was never hooked up? The gang that sold it too me indicated it was due to the electric start put in. Interior I have no tach, no clock and of course, DB we know about the radio.
Old Jul 29, 2008 | 09:39 PM
400hp427vette
St. Jude Donor '09
Your fuel filter is aftermarket J/k But might need to be replaced. It may be one of the causes of your problem
Old Jul 29, 2008 | 09:41 PM
dbeall1968's Avatar
dbeall1968
I would give it a little more time....
Rickster- you are off to a much better start than some of us. You have more right than wrong, so it's only a few little things for now. At least you are up and running
Old Jul 29, 2008 | 09:42 PM
Rickster - C3 69
I'm such a rookie. Don't even know which part is the fuel filter. I'm an engineer by trade, but just because I have "engine" in the title, doesn't mean much.
Old Jul 29, 2008 | 09:43 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Your fan shroud is probably correct. It looks like the one that was on my 70 when I got it. My 70 was a base car, 350/300 with a 4 speed and no AC. I am guessing yours in close to that because of the radiator shroud. If you are going to keep the mechanical fan I believe I would look into finding a clutch fan. Yours is way better than mine was when I got it. Keep at it and have fun with the car. One small project at a time and you get it where you want it eventually. I still find things I would love to do to mine. Just have to find time to do them.
Old Jul 29, 2008 | 09:50 PM
400hp427vette
St. Jude Donor '09
Trust me. The more you learn the more you find wrong. Some see my car as great but I know it will take thousands more to make it right. Example. Radio and speakers missing, windows have scratches, Wiper systems needs adjustments,passebger side seat bealt missing, air system missing. Thats just off the top of my head. Once you get into this fun/madness the point is you will always find something thats needs to be fixed. You do have a great starter car. But longer you own it and love it the more you will try top make it just right.
Old Jul 29, 2008 | 10:38 PM
Theiskell's Avatar
Theiskell
The glass or plastic fuel filter has been the subject of several safety threads. (an inside joke) On learning about the engine one of the best thing you could do is join a local club. You will find people who have the same interest as you and be willing to teach you. Some good basic hands on experience with someone who knows what they are doing will be priceless. Like the others have said you have a great platform to start with and it sounds like you are willing to learn. So dig in and get your hands dirty.
Old Jul 30, 2008 | 08:15 AM
Rickster - C3 69
Thanks everyone. Some good stuff here. I plan to tackle one at a time for sure. First is the radio, since we have it running, would be nice to have the tunes to go with it.
Old Jul 30, 2008 | 08:45 AM
sxr6's Avatar
sxr6
Don't get all hyped about originality unless your after a show car. These things are 40 yrs old Do what you think is right to suit yourself. After all the fun is in the cruise, so make it run right & have fun
When you lift the hood most wouldn't know what's original anyway
Old Jul 30, 2008 | 09:14 AM
Rickster - C3 69
Thanks. I plan on being in Carlisle on the Friday of the show (maybe more days if we really don't get enough on Friday). But I plan to talk to as many people as possible and take a lot of pictures of cars for ideas. I'm really psyched to go. Probably most of you guys wouldn't believe that I live only 20 minutes from Carlisle (been here since 92), have always wanted a Vette, but have never been to the show.
Old Jul 30, 2008 | 09:16 AM
GD70's Avatar
GD70
I agree with al the above comments. You are at a good start point.
The tach probably wasn't connected to the HEI distributor when it was installed. I didn't notice if there is a tach cable hanging loose coming out of the firewall.
Once you really start to clean everything under the hood, it will look much better right away.
Is the block numbers matching? It appears you have an LT-1 intake on there and who ever replaced the air cleaner specifically put a 370 horse power sticker on there. Does it have a Holly or Quadrajet carb? LT-1's were officially offered in 1970, but could be dealer installed in 69. A friend of mine has one. Just curious.
Glenn
Edit, just saw your other thread re: rebuilt to LT-1 specs.
To My engine
Old Jul 30, 2008 | 09:21 AM
Durango_Boy
Yeah just a high temp thread sealant. Permatex is a good brand.
Old Jul 30, 2008 | 09:39 AM
Rickster - C3 69
I believe (from what I have been told and how it was advertised) that it was a re-built engine to LT-1 spec. This didn't mean anything to me, I was shopping for a driver, within specific model years (1969-1972) - wanted chrome bumpers, look of the C3 and "Stingray" insignia on sides (eliminated the 68 off my list). My mechanic who looked over the car after I purchased it, said the carburator and cam were likely put in to match up. I could not tell you what brand each is (I need a map just to identify them!). But not a numbers match by any means: engine doesn't match, paint does not match for sure - should be silver, but I love the blue.
Old Jul 30, 2008 | 10:14 AM
Durango_Boy
If you can look at your engine using these pics for guides, can you get us these two numbers for block identification?
Block Casting Number:
Block Date Code:
Here is a view of the back of a bare block. The part where the numbers are cast is the part that the transmission bolts to. You may have some grime to clean off before you see them and GM had a habit of sometimes moving the date code around so you might have to search. Using these numbers we can help you figure out exactly what your engine is and when it was cast.
Closer view of the casting number.
Closer view of the date code.
