Why remove all paint?
Old Aug 12, 2008 | 06:39 PM
vett us all's Avatar
vett us all
Originally Posted by PKguitar
Sorry to sound stupid, but what is "DA"?
Democracy Alliance
Old Aug 12, 2008 | 09:31 PM
champs65's Avatar
champs65
I have had the good fortune to have owned 2 C3s' a 68 and a 69--that have had multiple coats of different color paint--5-6 plus!
It sure is good to know what you actually have to work with underneath
when you realize that prior owners just added coat after coat--God could only guess what else has been done to the body over the years.
Stripped them both bare; one had a terrific body underneath; the other,well...
DA'd and hand sanded all the tight areas (tail panel, rear window area, B-Pillar, gills, front valence and whatever else made common sense). Time consuming, results good. IMO, Merka sandpaper holds up the best.
Old Aug 12, 2008 | 11:24 PM
Smokin Joe's Avatar
Smokin Joe
I sprayed the lizard skin on. They say you can roll it, but it was real easy to spray.
Old Aug 14, 2008 | 12:07 PM
70Yellowbird's Avatar
70Yellowbird
I have a question for those of you with paint removal experience ... does your paint removal include the painted surfaces under the hood, inside the doors, and any other areas that don't show unless you open the hood, doors, etc.?
Thanks.
Old Aug 14, 2008 | 12:23 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
It all depends upon what level of inspection,
you wish to have your car reveiwed.
"Show car quality is every detail."
Fred's farm truck ... who cares !
only the cows will see it.
Old Aug 14, 2008 | 02:38 PM
stinger12's Avatar
stinger12
Thanks.
I only have experience removing paint from my vette, but yes. I remove absolutely everything. Even the stuff you will never see in the future unless you tear the interior down. I don't care what other people don't see. If I know its there and looks like crap, then I'll redo it...but that is just me. To each his own.
Old Aug 15, 2008 | 09:49 AM
1stCorvette69's Avatar
1stCorvette69
My car was painted 4X and looked like it was sanded with a brick and painted with a mop. No choise it has to go down to the fiberglas, I started with a razor blade then a DA (stay away from the edges and hand sand after) in tight spaces I used stripper,I am finaly done and awaiting new paint.
Old Aug 15, 2008 | 12:44 PM
sly vette's Avatar
sly vette
I will repeat what I have said on this forum many times with NO feed back, so obviously you guys aren't trying it!!!
A heat gun on low with a round edge putty knife works wonders on old thick paint and all the old filler that has to be removed...For the most part.
All paint removal will require some good old fashioned manual labor!!!IMHO!!! (Hand Sanding)
Mark
Old Aug 15, 2008 | 02:20 PM
vett us all
Old Aug 15, 2008 | 10:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by dodge_ss/t
if its already been repainted and the body work is good the just take it to the primer and call it good. that's what im doing, no point in fixing what's not broke.lol
If it's a good candidate and it is done right you can get good results without completely stripping the car
