Block Coating?
Old Aug 12, 2008 | 10:34 AM
Durango_Boy's Avatar
Durango_Boy
Default Block Coating?
What is that coating called that you can put on the lifter valley walls to keep oil from sticking and lets it run off easier?
I have a few things I want to coat.
Old Aug 12, 2008 | 10:40 AM
etteroc's Avatar
etteroc
it's called paint
Old Aug 12, 2008 | 10:43 AM
ImBatman's Avatar
ImBatman
"Glyptol" I think that is the name.
Old Aug 12, 2008 | 10:44 AM
V-Twin's Avatar
V-Twin
Actually it's Glyptal.
Old Aug 12, 2008 | 10:53 AM
Durango_Boy
Originally Posted by etteroc
it's called paint
I would never paint a lifter valley with spray paint...how you wouldn't either.
Yep, that's it, thank you very much. For some reason I had the name Nyalic in my head...and that's just a clear coat.
Old Aug 12, 2008 | 11:34 AM
bojangies46's Avatar
bojangies46
Way back in the old days we used Rust-Oleum, worked great
Old Aug 12, 2008 | 11:41 AM
SteveG75's Avatar
SteveG75
Glyptal:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Aug 12, 2008 | 12:15 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i've always had a problem with doing this on a street engine. Any coating will eventually heat cycle harden, then crack and flake off. I just don't know how you get the block oil free enough to get good adhesion.
Remember a lot of these techniques are intended for race engines that get torn down after a year or less.
Its not going to last 20 years in a street engine.
Old Aug 12, 2008 | 12:52 PM
dtamustang's Avatar
dtamustang
that hot oil on the bare cast iron also aids in heat transfer, i read somewhere it was a lot of trouble for no gain of any kind. all of that with a possible huge downside if the coating doesn't stick. i would think long and hard before i did it.
Old Aug 12, 2008 | 01:05 PM
Durango_Boy
I guess it all comes down to what day you ask and who answers.
I could ask this another day, or read when someone else posted it, and they get nothing but comments from guys that use it religiously and love it.
I have flip flopped a few times on this. I have the chance to put it on in my 405 before I complete the build. I was originally talked into it, then out of it, back into it, and now...back out of it.
Hard choice to make. I don't want to affect cooling, but I like the idea of the oil getting back down to the sump faster.
Man o man.
Old Aug 12, 2008 | 01:30 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's my opinion too. If you don't have an oil cooler, using some of the cast iron to transfer (oil) heat to the coolant jacket for disposal seems like a freebie to me.
Besides, painting the internals of a street engine always made me uncomfortable. I gotta agree with Turtle's comment about flaking paint (heading straight for the oil pump screen).
Old Aug 12, 2008 | 01:31 PM
dtamustang's Avatar
dtamustang
my gut feeling is that it doesn't effect cooling enough to worry about, but i also have a gut feeling that unless you are doing some serious driving,long sweeping high speed turns where there is a possibility of your oil pickup sucking air ,painting the lifter valley to get max oil return is not going to matter a whole lot one way or the other. i have heard of some guys who have opened up the return holes to a larger size and deburred the lifter valley,i assume that would help.
if you want a little more to ponder i also knew a few guys who painted (glyptal) everything, lifter valley , underside of the block timing chain area, everything that had oil draing back to the pan,their reason was to trap anything abraisive under the coating to keep it from getting loose and doing any damage.
hope i didn't confuse things even more
Old Aug 12, 2008 | 01:39 PM
rcread's Avatar
rcread
Over on the Pontiac forum I frequent, a forum member took the valve covers off for the first time and discovered his rockers had been painted with a metallic paint that had flaked off. Now he has to take his engine apart to flush the paint out of it. Lesson: don't paint your rocker arms (though I think anyone who is smart enough to read is also smart enough to know this already).
noonie's Avatar
noonie
To speed oil return and to try and prevent buildup, you can always deburr and polish those areas. It's a lot of work and the block will have to be cleaned again.
Old Aug 12, 2008 | 01:49 PM
dtamustang's Avatar
dtamustang
i was under the imression polishing the lifer valley was not a good idea, hurts the heat transfer
Old Aug 12, 2008 | 02:08 PM
noonie's Avatar
noonie
I don't bother with either, but I would assume the oil is doing most of the heat transfer in all cases.
BTW, I while back I took a forklift engine apart that hadn't been apart in 15 years that I know of, and it had a painted coating on the internals that had not deteriorated.
Old Aug 12, 2008 | 02:31 PM
dodge_ss/t's Avatar
dodge_ss/t
it's called paint
when (cus it will) comes off it can and will cause damage to the motor. most paint dosnt play nice with oil
To Block Coating?
Old Aug 12, 2008 | 02:37 PM
ctk30's Avatar
ctk30
No paint on the block at all is best, A raw block will run the coolest
Old Aug 12, 2008 | 03:05 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Among the reasons they began to paint the inside block surfaces was to seal in any potentially loose casting flash or sand that might fall off. Another was the aforementioned faster oil drain back, which I contend is probably negligible at best. On the typical street motor does anyone really have a big problem with oil not returning to the sump quickly enough?
In my opinion if it's not there, it won't cause any problems
Old Aug 12, 2008 | 06:57 PM
vett us all's Avatar
vett us all
Man o man.
I beg to differ with all the nays on this subject. The product has been used in electric motors that makes large amounts of heat, soaked in oil. I coat the lifter valley, head cavities, and the front of the block where the timing cover, covers. Never had problems as long as the areas to be coated are perfectly clean and dry......... Go for it
