Pitted metal
Old Aug 14, 2008 | 06:06 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Pitted metal
Is there any type of "liquid metal" that can be used to fill pitted metal? Seems like I remember something called Liquid Steel from many years ago.
Old Aug 14, 2008 | 06:21 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Depends on yor application, but in reality NO.
There is some epoxies that you can use to fill in cosmetics. like JB weld.
Put if you think you can polish it, or use it in a cylinder wall, you can't.
Old Aug 14, 2008 | 06:43 PM
ctk30's Avatar
ctk30
Heat it up to about 3000* and it will be liquid
Old Aug 14, 2008 | 09:01 PM
Dr L-88's Avatar
Dr L-88
I've done that with aluminum powder, but it doesn't take 3000 to melt it. When melted, it can be molded or used to fill imperfections, but better be careful..................it burns real good................I know.
Old Aug 14, 2008 | 09:56 PM
weimer20's Avatar
weimer20
Lead. Nowadays you can't find anyone that knows where the term lead sled came from. I know there are some old school hot rodders here on the forum that do though.
Old Aug 14, 2008 | 10:16 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
As stated above lead was often used to fill imperfections on bodywork.
Old Aug 14, 2008 | 10:20 PM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
I'm one. 50 Buick. One of those unfinished teen projects.
Old Aug 14, 2008 | 10:48 PM
3JsVette's Avatar
3JsVette
Not sure what you want to use it for but POR 15 makes some fillers that should be up to the task if you're trying to make a frame look new. Take a look at this http://www.por15.com/prodinfo.asp?grp=PU&dept=10 as well as some other fillers they carry.
Old Aug 15, 2008 | 08:03 AM
Dr L-88's Avatar
Dr L-88
That may just work!! Thanks for the tip.
Old Aug 15, 2008 | 09:24 AM
weimer20's Avatar
weimer20
Nice!
Old Aug 15, 2008 | 10:17 AM
wro87's Avatar
wro87
Not Real sure on what you need for your application. We have used a product caleed LAB METAL 9 you can get it a (FASENTAL). I have used it for cleaning up some welds and pitting in aluminum and steel befor we would powder coat. It is made for foundry mold repair. You can bruxh it on and then must let it sir dry for 24hrs at 70 deg. then bake it at 500 for an hour before we powder coat it. After it is set up you can do just about anything to it. Good luck wro87
Old Aug 15, 2008 | 12:14 PM
tmacb's Avatar
tmacb
That sounds really interesting. Is it difficult to work with? Is it sandable/shapeable before the baking process?
Old Aug 15, 2008 | 02:09 PM
7T1vette's Avatar
7T1vette
If the pitting is in a "pot metal" part, you can't use anything that melts higher than about 500 degrees F to fix the pits. Pot metal is a low melting point amalgum of inexpensive metals and will just turn to a liquid when it gets that hot. If you want to plate it when you fix the pits, just take it to a good plater and let them know it is made of pot metal. (Of course, if your part is NOT pot metal....nevermind...)
To Pitted metal
