Fan Assembly
Old Aug 21, 2008 | 07:02 PM
Lilfur's Avatar
Lilfur
Default Fan Assembly
I am looking for radiator fan shroud ,fan blade , and fan clutch for my 68 big block,no A.C. and also the correct pully. Does anyone have the org. part numbers that I would be looking for??? I have a electric fan on it now , and want to go back to orig.
Old Aug 22, 2008 | 10:55 PM
GPGG70's Avatar
GPGG70
427 & what HP from factory. What type of carb set up was on the car new out of the factory?
Old Aug 24, 2008 | 07:24 PM
Lilfur's Avatar
Lilfur
Sorry forgot to mention that :427 -435 w/ 3 x 2
Old Aug 24, 2008 | 08:36 PM
GPGG70's Avatar
GPGG70
Hope I dont disappoint you but was only able to come up with a couple of numbers.
Fan Blade, w/o AC = #3888366= same as 66-67 427 cu.in. 5 blade 17 1/2" dia.
Fan clutch, w/o ac, 427/435hp 3-2. 1st design early 68 #3916141.
2nd design late 68 # 3937771.
You might want to double check these numbers again.
This book I have doesnt have the numbers for any pullys or the fan shroud which I find hard to believe but you might be able to cross reference the info with this numbers. Hope this helps.
Old Aug 25, 2008 | 02:55 PM
Lilfur's Avatar
Lilfur
Thank You
Old Aug 26, 2008 | 12:23 AM
GPGG70's Avatar
GPGG70
Thank You
Your welcome. I was at a cruize in last weekend and a guy had a 69 427, 3-2. Now I want one.
To Fan Assembly
