Open element air filter
Old Aug 28, 2008 | 01:00 PM
Bruce Wayne's Avatar
Bruce Wayne
Default Open element air filter
What do you guys recommend doing with the valve cover vent tube when switching to an open element air filter? It's a 1978 L82 350.
Old Aug 28, 2008 | 01:22 PM
PETKAH's Avatar
PETKAH
Take the tube out and replace with a breather. Cost $8 to $50 depending on how fancy you want to be. When shopping take the current grommet with you to make sure you get the correct fit.
Old Aug 28, 2008 | 01:32 PM
BKbroiler's Avatar
BKbroiler
The open element unit I have came with a plastic elbow fitting to install in the bottom of the air cleaner housing. I shortened the stock metal tube and connected a short rubber hose from the tube to the elbow. Doesn't look too bad.
Old Aug 28, 2008 | 03:35 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
That's the ticket. The stock open element systems did exactly that. Valve cover to air cleaner bottom via a hose.
Old Aug 28, 2008 | 04:13 PM
Bruce Wayne
Thanks Guys
Old Aug 28, 2008 | 06:00 PM
thegazman's Avatar
thegazman
Default thegazman
Here's what I did with my passenger side vent.
Old Aug 28, 2008 | 06:12 PM
Glassbowtie77's Avatar
Glassbowtie77
Here's mine, open air cleaner with a chrome breather in the passenger side valve cover.
Old Aug 28, 2008 | 11:16 PM
Bruce Wayne
Looks good. Where can I get one?
Old Aug 29, 2008 | 09:06 AM
thegazman's Avatar
thegazman
Default thegazman
You buy breather vents at a lot of places. The local Advance Auto has them or you can order the vents from Jegs or Summit.
Old Aug 29, 2008 | 09:56 AM
MikeMc71's Avatar
MikeMc71
I bought an Edelbrock at CHecker Auto Parts, It was about $10 I think, its been a while.
To Open element air filter
