Gaskets & such
Old Sep 6, 2008 | 11:49 AM
Dick72LT1's Avatar
Dick72LT1
Default Gaskets & such
I'm about to start the re-assembly on my 72 LT1. I have a few simple questions to solve future problems.
1. Should I use Teflom tape or some kind of RTV sealant when attaching the dual fuel lines to the carb?
2. I'm replacing the old fuel tank with a SS tank. Should I use RTV or other sealant on the neck gasket?
3. Should I use RTV on both sides of the coolant neck on top/front of engine?
4. Same questions for fuel pump installation: RTV on paper gasket?
Thanks. Exciting times ahead.
Dick
Old Sep 6, 2008 | 11:58 AM
Gordonm's Avatar
Gordonm
1. NO. No tape is needed on these fittings.
2. Would not hurt for a slight bit of RTV
3. I use a little. Just a thin film.
4. I use high tack gasket sealer on the paper ones like this. It is a spray adhesive that works well.
Old Sep 6, 2008 | 02:41 PM
7T1vette's Avatar
7T1vette
I don't recommend using RTV on any paper gaskets. Use a little wipe of Permatex on both sides...either the black gasket sealer or the Hi-Tack.
Old Sep 7, 2008 | 10:10 PM
Dick72LT1's Avatar
Dick72LT1
Thanks, guys. I'm not familiar with the hi-tack stuff. I'll check it out.
Dick
To Gaskets & such
