fuel gauge problem
Old Sep 14, 2008 | 04:13 PM
rolando hernandez's Avatar
rolando hernandez
2nd Gear
Default fuel gauge problem
79 corvette fuel gauge only registers up to quarter tank. changed sending unit same problems. any ideas?
Old Sep 14, 2008 | 08:21 PM
7T1vette's Avatar
7T1vette
Did you disconnect all the electrical connections...including the ground wire...and clean them all up? Corrosion on one of the connectors will increase resistance and throw off the reading. {Hopefully, you didn't waste your money on buying the sender...}
