Replace rear Carpet
Old Sep 16, 2008 | 05:48 PM
slick1964's Avatar
slick1964
4th Gear
Default Replace rear Carpet
I am replacing the rear carpet of my 78.
In addtion to the carpet and underlay, is there anything else I need
Old Sep 16, 2008 | 06:06 PM
Duke94's Avatar
Duke94
Spray carpet adhesive and a heat gun (hair dryer).
Old Sep 16, 2008 | 06:46 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
A soldering iron, round tip, to easily and smoothly make the three retaining holes in the back carpet where the plugs go. I bought the plugs and plug kit too and it helped seat those three plugs nicely.
Good luck with the install and let me know if you want to see pictures of mine which I completed last month, went pretty smoothly.
David
Old Sep 16, 2008 | 07:03 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
New trim rings for the storage compartment doors because ya pretty much gotta destroy the originals to replace the carpet on the comp doors.
It's been a while, but I don't recall needing any adhesive anywhere but on the 3 doors and there's no plugs needed on the 78-82 rear carpet. Pretty much tucks in and clips on.
Old Sep 16, 2008 | 07:08 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I didn't pay close enough attention to the year, my apologies. I redid my 77 and needed the holes, sorry about mistating the need for a 78. I'll pay closer attention next time.
Thanks and best regards,
David
Old Sep 16, 2008 | 08:24 PM
LittleJake's Avatar
LittleJake
One thing nobody mentioned is dynamat, while you have the carpet out I would put some type of heat barrier and sound barrier underneath the carpet. Search in the forum for dynamat and reflectix that should bring up a few threads.
Good luck!
Old Sep 16, 2008 | 10:03 PM
7T1vette's Avatar
7T1vette
No need for heat insulation in the storage compartment. There isn't any heat source close enough to need it. Dynamat? Well, if you are an audiophile and a Corvette enthusiast and have attempted to mix those together.... I always thought that reducing noise in a C3 Corvette was "blasphemy"!
Old Sep 17, 2008 | 06:18 AM
slick1964's Avatar
slick1964
4th Gear
Thanks alot
Old Sep 17, 2008 | 09:03 AM
ngroat7007's Avatar
ngroat7007
trust me dynamat does not block everything
Old Sep 17, 2008 | 09:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When you pull out the old stuff, keep an eye out for a build sheet. Occasionally, copies of build sheets have been found under the rear carpet.
Good luck.
Old Sep 17, 2008 | 09:14 AM
75 Red Vert's Avatar
75 Red Vert
Be sure and keep the old carpet to use as a template for the new.
To Replace rear Carpet
