HELP? Speaker replacement
Old Sep 19, 2008 | 10:18 PM
glassman74's Avatar
glassman74
Default HELP? Speaker replacement
Have replaced speaker on PS of my 74 coupe. No problem.
The DS looks like a PITA. Did search, and found many opp. on how to do it.
The car has org. dash, so moving it around is scary. What is the best way w/o
moving dash around?
Thanks in advance. glassman74
Old Sep 21, 2008 | 01:05 AM
Richard454's Avatar
Richard454
You can drop the steering column...try to move the gauges-have to unhook speedo and tach...then realize you still can’t get to the speaker....
OR-take off trim around windshield (sunvisors /center /left and right windshield pillars)). Take the top screws out of the dash (driver side) and hopefully you haven’t put the pass side back together because that needs to comeback out... Then carefully flex the dash as you pull it out from the passenger side.
Richard
