Strip dynamat reflectix... carpet
Not completely done yet but here are some pics for the install its taken about 2-3 hours so far
I cant find pics from before but trust me you didnt want to see them...
first i stripped the carpets and original juke? jute? whatever and then rubberized the floors and panels wth a product found at home depot
I would suggest you do not rubberize if you plan on using dynamat... i found out the hard way
The dynamat is extremley easy to use. It cuts easy stick to anything you would like but can come off easy as well if you havent pushed it down yet. For all interested in dynamat do yourself a favor and get the roller without it its not to fun. Another note the edges of dynamat extreme are razor sharp when cut keep that in mind.
it cuts deep so beware dont find out the hard way
after all dynamat was in place install reflectix where needed...
aluminun or foil backet tabe is great for the job
Repeat where needed
and just a loose fitof he carpet
and finally get a family member to give the pet duck a ride
but not in the vette...
reflectix if just one of the smaller rolls it was only like $30 from lowes and it was more than enough. i didnt do the entire rear section because i heard it is a waste just the whole driver and passenger side and the rear where the juke was previously
Btw, great job on the installation ngroat. Since I recently did it, my fingers are similar to yours, i have small cuts all over and some deep cuts. But hey, no pain no gain, right?
Strongly recommenmd insulating the tunnel...major heat source and made a big difference in my 79
I think every Dynamat installer has this pic...heed the warning!
Best of luck, Steve
hahaha you have one too!
This is something we never got a warning about so everybody listen up!
Im not done yet i actually need to get more dynamat but would you suggest insulating everything? The tunnel is going to be my project today
Take you time on the tunnel and be real careful to make sure all your wiring is still shielded and makes little/no contact with the Dynamat/Reflectix...the metallic surfaces can be quite conductive.
Keep up the great work!
S
13 sheets of Dynamat (with virtually no waste) will do the entire passenger compartment and rear of a 78 - 82. 3 more sheets will do the doors also = 2 bulk packs. $119 (with shipping included!) is the best price I could find and is about half of retail.
