Braille Power Protector
Old Sep 27, 2008 | 07:30 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Braille Power Protector
Anyone using this?
I think every car should have something like this.
especially a C3 that might sit for a week or two.
http://www.jegs.com/i/Braille%20Auto...RBPP3/10002/-1
Braille Power Protector Features:
* Never-Dead Battery Protection: The Braille Power Protector monitors battery voltage and usage with the vehicle running and when it is turned off. If it senses that the usage of the battery when the vehicle is turned off will exceed the amount of power needed to start the vehicle, the Braille Power Protector will disconnect the battery and protect it from being drained. This saves you from being stranded and wasted time due to a dead battery. It also avoids towing costs and extends the life of the battery.
* Remote Control Battery Connection: Using a small key fob, you can connect and disconnect the battery. You can also operate the key fob to reconnect the power after the Power Protector has prevented a dead battery.
* Anti-Theft Protection: Using the Remote you can disconnect the battery, preventing theft of the vehicle while away.
* Passive Power Allowance: The Power Protector can be set up to allow some small amounts of power to serve the back up radio, ECU and clock functions in the vehicle.
* Easy Installation: To install the Braille Power Protector, simple hand tools make this a bolt-on job. Comprehensive instructions with diagrams are provided to aid installation for many different vehicle applications and mounting configurations - this is a universal product for all vehicles
* Low Cost: With a cost the Braille Power Protector takes the worry out of buying a small lightweight battery for daily use. And those that store their race, street or show vehicles for long periods of time will be able to easily ''walk away'' from the car and simply click a button to disconnect the battery for storage.
