Wiper overide switch
Old Sep 28, 2008 | 07:43 PM
Jim71Vette's Avatar
Jim71Vette
Default Wiper overide switch
How is the **** removed? This would be the switch between the headlamp and wiper door overrides.
Old Sep 28, 2008 | 08:04 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
You should be able to pull the **** right off...but be careful not to pull at it on an angle or you can crack the collar
Old Sep 28, 2008 | 11:04 PM
vettebuyer6369's Avatar
vettebuyer6369
I have a broken stud where the **** is supposed to attach. I see the **** alone as a replacent part. Is the rest available?
Old Sep 28, 2008 | 11:12 PM
...Roger...'s Avatar
...Roger...
There's no set screw?
Old Sep 29, 2008 | 05:23 PM
Alan 71's Avatar
Alan 71
Hi Jim,
I believe the **** is a 'slip' fit, like old radio/tv ***** were. No set screw.
Dr.Rebuild has the switches; sit down, no, lay down before you read the price of the NOS switch. The replacement is 1/5th the price. But, your car deserves ONLY THE BEST, right?
Regards,
Alan
Old Sep 29, 2008 | 07:42 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
On my 69 it has an allen key set screw
http://www.corvetteamerica.com/cf/di...ord%3A%2030040
Part# 30040
Old Sep 29, 2008 | 09:38 PM
Alan 71's Avatar
Alan 71
Hi 400/427,
You made me look on this one!!!
I believe the 68-72 ***** didn't have the SS center and set screw the Corvette America **** shows. The one they show is either a service replacement or a reproduction.
Now it certainly is a suitable replacement and the difference only matters to people like me that have nothing better to do than go look at the car in the basement.
Regards,
Alan
Old Sep 29, 2008 | 10:38 PM
400hp427vette
St. Jude Donor '09
So the factory ones had no set screw?
Old Sep 29, 2008 | 11:07 PM
vettebuyer6369
I dont think they did. I see Corvette Central sells a 70 and later ****/switch as a replacement for 68-69, as it seems they are discontinued.
An NOS on ebay is $250.
Old Sep 29, 2008 | 11:48 PM
early shark's Avatar
early shark
Jim71Vette,
Both of my '71's ***** do not have any type of set screw arrangement for attachment. It looks to be a press on fit.
Old Sep 30, 2008 | 09:45 AM
corvetteload's Avatar
corvetteload
no set screw!!! Just pull off
Old Sep 30, 2008 | 10:52 AM
Jim71Vette's Avatar
Jim71Vette
Thanks to all - it did just pull off.
To Wiper overide switch
