Body lifting question
Old Sep 28, 2008 | 10:40 PM
Dream Bikes's Avatar
Dream Bikes
Default Body lifting question
I'm going to lift the body in the next weeks so I'm building a steel body dolly...
My rocker channels aren't in good condition (quite rusty as the frame), so I think the best way could be the 6 buds lifting method
But I've still engine and gas tank on the frame and I'm not sure about the hand power max. lifting height Could be enough to drop engine and gas tank???
Sure,remove the carburator should help, as lower the frame without wheels
I know that also the gas tank can be removed before body lifting but I don't know how exactly! Any suggestion???
Old Sep 29, 2008 | 08:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Noland Adams has a body lift workbook and video. It's for C2s, but the processes are essentially the same for C3s. Eckler's has it and it's available through the NCRS.
http://www.ecklers.com/product.asp?p...os-_-53043-_-X
Good Luck.
Old Sep 29, 2008 | 10:29 AM
72LS1Vette's Avatar
72LS1Vette
If you unbolt the straps holding the gas tank and unbolt the crossmember the tank will come down. There are hoses on each side of the tank as well as the sender wire that have to be removed also. Removing the carb and distributor will get you as much clearance as possible without removing the engine. You shouldn't have to lift the body very far to clear the engine. The gas tank is the highest point.
Rick B.
Old Sep 29, 2008 | 01:05 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
The fuel tank and carb are the two highest points (the carb is slightly higher). The fuel tank pull will require the removal of the spare tire carrier, exhaust, and crossmember with straps. Not real challenging, but a dirty job from the bottom.
If you do not pull your carb, at least remove the stud for the air cleaner.
Enclosed is a side angle of my chassis to give you an idea on height.
I was lucky enough to have a 4 post lift to facilitate the removal.
Good luck.
Old Sep 29, 2008 | 01:26 PM
Dream Bikes
Thanks for the help!
Removing carburetor and distributor isn't a poblem, but removing the gas tank could be not so easy
Exhaust and spare tire carrier bolts/nuts are seized
Really a dirty job, but I will try to do it
Old Sep 29, 2008 | 02:37 PM
gearheaddroppings
Cutting the exhaust off might be your best option to get it out of the way. As for the carrier nuts, I fashioned a deep well 6 point socket with a thin bolt in it and ran it on an air impact (the end of the carrier bolt is nothing more than an oval with two flat ends). I ended up getting one of them out using this method. On one side I broke the boss off inside the crossmember. There are access holes to pull it out after I ground off the carrier bolt. It is a royal pain. Air tools are your friend.
Old Sep 29, 2008 | 04:51 PM
al329's Avatar
al329
You can also gain more little height by removing the wheels and lowering her down onto wheel dollys or blocks.
Old Sep 29, 2008 | 07:22 PM
ottawa77's Avatar
ottawa77
I cut the exhaust off and left the gas tank and carb on.6 guy's would really not be enough.It took eight including 1 person to postion the body dolly.Also you may have a few wires left underneath to cut.At least i did.Good luck..
Old Sep 29, 2008 | 09:17 PM
depdep3's Avatar
depdep3
I just lifted my a couple months ago. Here are some things I learned....
I was worried about height also. I did not remove the gas tank and left the engine with carb in place. I was able to lift the body in a standard height garage with some wiggeling and jiggeling, but no major difficulties.
I wanted to save my paint so I was being pretty careful and kept the straps closer togeter then I would have prefered. No big problem, but caused the nose to drop low.
If you use a lift like the one in the picture make sure it does not colide with the dolly. I had to remove one of the 2x4s to get the dolly under the car.
Good Luck
Old Sep 29, 2008 | 09:36 PM
Dream Bikes
You're right, air tools are very friendly but people often forget it
Old Sep 29, 2008 | 09:38 PM
Dream Bikes
Yes, I know
I'm also building 4 wheel dollys like these :
Really an easy job !
Old Sep 29, 2008 | 09:40 PM
Dream Bikes
Why did you cut the exhaust without removing the gas tank??
I will buy enough beer for 8 buds
Old Sep 29, 2008 | 09:43 PM
Dream Bikes
Good Luck
Thanks for the imput If the 6-8 guys method will works, I shouldn't have this problems..
Old Sep 29, 2008 | 10:05 PM
Maine Vette's Avatar
Maine Vette
I also used an engine hoist to remove my body, but it just barely was able to lift the body high enough to clear the carb and gas tank. To reinstall my body I've created an overhead lifting frame with two chain hoists, it should work much better.
So why are you building a steel body dolly? A wooden one would be much cheaper and easier to construct?
If you think it might help you can see photos of my body lift and read some narratives on it at my website www.corvette-restoration.com. The body lift is under the first update.
Good luck!
Tim
Old Sep 29, 2008 | 10:41 PM
...Roger...'s Avatar
...Roger...
Where are these guys going to grab onto the body?A good lifting jig is important to keep from damaging the plastic.
Old Sep 30, 2008 | 11:18 PM
Dream Bikes
Good luck!
Tim
Because I've some steel here in my garage and no wood (which here in Italy isn't so cheap! ).
Tim, your website is awesome and very useful for my frame-off project I'm following it since last year
You're doing a wonderful job
Old Sep 30, 2008 | 11:20 PM
Dream Bikes
Originally Posted by DWncchs
Where are these guys going to grab onto the body?[/IMG]
With 6 guys I suppose : 4 grabs the fenders and 2 grabs under the doors
With 2 more : one to the nose and the other to the rear end ?
To Body lifting question
Old Sep 30, 2008 | 11:28 PM
...Roger...
I've never seen guys pick one up but it would have to be awkward to pickup.
Doing the math depending on what you leave on the body each guy will have to lift around 170lbs.
edit-more guys,more beer?
Old Oct 1, 2008 | 06:50 PM
Dream Bikes
I'm going to lift the body without interiors, rear window, doors, hood, radiator and headlights. I will leave only t-tops and radiator support for more stiffness
More beer? We are in October...will be the "October Fest"
Old Oct 3, 2008 | 08:36 PM
Lou68's Avatar
Lou68
I used a block and tackle rated at 1000lbs and worked easily on my 68 coupe. Having four others friends will also be a big help as well. Prior to lifting the body, the drive train, fuel tank, radiator were removed. I kept the t-tops, doors and radiator support on for stability. I will post pictures later on.
