dyeing seat belts
Old Sep 29, 2008 | 08:30 AM
blue by you's Avatar
blue by you
Default dyeing seat belts
Wondering if anybody has dyed their seat belts, looking to go from black to blue. Thanks in advance
Old Sep 29, 2008 | 08:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I used SEM automotive interior dye. Shoots like lacquer and I haven't had any problems with it.
Old Sep 29, 2008 | 09:03 AM
blue by you
did you have to do anything to the belts before you dyed them and how many coat before they cover.
Old Sep 29, 2008 | 10:08 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I understood they would not take dye very well. Tell us more.
Larry
Old Sep 29, 2008 | 02:13 PM
7T1vette's Avatar
7T1vette
SEM vinyl dye will work just as well on nylon belts it does on plastic panels. What doesn't work well is RIT fabric dye. It actually says in the instructions that it is not intended for polyester materials. P.S. I would stay away from the aftermarket places that say they are selling aerosal can "dye". From discussions on this Forum, it is doubtful that the stuff is anything but spray paint with a different label. Get your dye from a professional auto paint supply store.
Old Sep 29, 2008 | 06:14 PM
RPOL68's Avatar
RPOL68
I just did a set of 67 Camaro belts with RIT Dye and hot water and it worked fine. I went from blue to black. I was hoping to keep the service lable dry but the belts wick up the dye and the lables and now black. This wasn't a restoration so I wasn't upset with the results.
Old Sep 29, 2008 | 08:33 PM
DJordan442's Avatar
DJordan442
i used RIT to go from gold to black on my 442 with great results. took the little tags off and then stitched them on later. look like new now.
Old Sep 30, 2008 | 08:07 AM
blue by you
ok thanks guys, I'll keep you posted on the out come.
Old Sep 30, 2008 | 09:45 AM
Easy Mike's Avatar
Easy Mike
I washed the belts (literally ran them through the washing machine). When they were dry, I shot the SEM. Went from black to dark blue. The first coat covered well and I probably didn't need the second coat.
Old Sep 30, 2008 | 02:44 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I also put two coats of the vinyl dye on mine (silver) last weekend. They look like new now. A bit stiff at first but roll them up and pull them out a couple of times and the stiffness was gone.
(did I really say that?)
To dyeing seat belts
