69 Manual Shifter problem
Old Oct 1, 2008 | 07:04 PM
Jack Ferris's Avatar
Jack Ferris
4th Gear
Default 69 Manual Shifter problem
I took the ball off and pulled the reverse lever/rod out to remove the console. I got it all back together and the shifter wont go into reverse now. What did I do wrong here? It worked before I messed with it. I did have the trans out as well but I just moverd the shifter off to the side.
Old Oct 1, 2008 | 07:44 PM
Duke94's Avatar
Duke94
Did you put the spring in BEFORE the T-handle? If so, that's your problem, the T-handle goes in first then the spring, then the ball.
Old Oct 1, 2008 | 07:53 PM
...Roger...'s Avatar
...Roger...
Did it myself once....shhhhh
Old Oct 1, 2008 | 08:55 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
so did i....had to make a hook out of wire and fish it out.........
Old Oct 2, 2008 | 09:58 AM
Jack Ferris
4th Gear
No I put the spring on top of the rod.
Old Oct 2, 2008 | 10:27 AM
...Roger...
Did you try removing the shift ****,spring and T bar and then trying to shift into reverse?
Old Oct 2, 2008 | 06:21 PM
Jack Ferris
4th Gear
Found the issue. I had the reverse linkage rod reversed. Fliped it over and amazingly enough it works. Thanks to all who replied.
To 69 Manual Shifter problem
