Front Side Marker Lights Question
Old Oct 2, 2008 | 09:05 PM
onaqwst's Avatar
onaqwst
sounds like a ground/hot issue..... maybe someone swapped out the connections before....
Old Oct 2, 2008 | 10:24 PM
wfo76's Avatar
wfo76
Originally Posted by juke3w1
UPDATE, After we talked about this last nite I had to study it more.
It seems that clear lens on the front side is a 1156 and only lights when the turn signal is flashing. But it doesn't flash(just a steady light).
The amber lens above the clear is a 168(GM manual) or 194 will work. It burns at all times when the lights are on, even when the parking lights are on. Now get this, when I pulled the bulbs(1st time they have been out) and put them back in they now flash with the turn signal.
So when you turn the turn signals on(either left or right) you are suppose to have the amber lens flashing and the clear lens on(but not flashing) on the chosen side.
When lights are on only the amber lens lights.
Hope this helps it's just a little screwy.
Thanks for the update and glad you got them all working right.
Old Oct 3, 2008 | 12:45 AM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Jclgodale3
My 81 lights up the top orange lens when the driving/parking lights are on. When the turn signal is activated it lights the bottom lens (white) on and the top orange lens blinks. As far as I know, this is how it was designed
Exactly as stated earlier
Old Oct 3, 2008 | 11:52 AM
wfo76's Avatar
wfo76
Yeah, you were right but with so many guys saying otherwise, it had me wondering.
Couldn't believe GM would design a car in 1982 with no front side markers and guess they didn't.
Old Oct 3, 2008 | 02:20 PM
WillEE's Avatar
WillEE
Wow - I'm going to try pulling my bulb out and putting it back to see if mine start working properly. How strange that so many would be having this issue on '82s. I orignally though it was kind of a dumb question but now 'm glad I brought it up.
Old Oct 3, 2008 | 03:03 PM
juke3w1's Avatar
juke3w1
Me Too. Sorry about the confusion at first. I got to thinking about it after I posted and knew it didn't make sense.
Old Oct 3, 2008 | 09:55 PM
Frank_833's Avatar
Frank_833
Also seems strange they would pass safety inspection if they have issues like that. Though I know many inspectors are lax on older cars. My vette won't fit in the bay at the place I use (too low). So it just gets a more cursory check.
