running rich - Help !
Old Oct 4, 2008 | 06:07 PM
My70's Avatar
My70
Default running rich - Help !
Took my 70 vert out for a ride, ran great, brought home and went to give it a quick wash. Finished car, didnt really wait for it to warm up again (didnt think it needed it) and started to drive around the block. all of a sudden car was bogging as if it was getting too much gas. It is difficult to keep car running (running rich - smell it in exhaust) Please let me know what you think. Thanks !!!!!!!!!
Old Oct 5, 2008 | 12:46 AM
TimAT's Avatar
TimAT
Maybe a choke problem.. Post some more info on what your engine/carb is it'll make it easier to give you some place to go look. Lots of other possiblities can cause a "running rich" condition.
Old Oct 5, 2008 | 02:35 AM
sly vette's Avatar
sly vette
Possibly a piece of dirt made it's way up to the needle/seat at the carb???
Old Oct 5, 2008 | 08:09 AM
My70's Avatar
My70
Its a 350/350 with a Rochester. Could vacumn or points be culprit? Its like you have to flutter the gas to keep it running and shakes like its missing (but would only pop if forced) worse under load (while in gear then idle) Thanks
Old Oct 5, 2008 | 08:11 AM
My70's Avatar
My70
I had gotten aorund half way around the block when this condition started (350/350 Rochester, M21) thanks
Old Oct 5, 2008 | 09:25 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
That is the most likely cause IMO.
Old Oct 5, 2008 | 11:01 AM
My70's Avatar
My70
So how do I correct this ?
Old Oct 6, 2008 | 08:01 AM
sly vette's Avatar
sly vette
Clean it! Partial disassembly required. Remove top of carb. to access float and the needle is right there.
Old Oct 6, 2008 | 08:30 AM
LT4Coupe's Avatar
LT4Coupe
First thing I would check is spark plug wires....make sure one end
has not come loose (off the plug, or cap).
Old Oct 6, 2008 | 08:58 AM
My70's Avatar
My70
checked cap wires [both ends] even changed plugs.
Old Oct 6, 2008 | 09:00 AM
My70's Avatar
My70
could you give me more of a description and or pics - thanks
Old Oct 7, 2008 | 10:45 AM
My70's Avatar
My70
Looks like it was a bad set of points. Check dwell it was low (20) couldnt adjust - replaced points, set to (30) seems okay now
To running rich - Help !
