align rear suspension
Old Oct 10, 2008 | 08:30 AM
vegabond's Avatar
vegabond
Default align rear suspension
Is there any way to obtain a correct rear wheel alignment myself on a 1981 corvette, (excluding a alignment shop which I dont trust) inc. trailing arm shims. This is a drag car only. Thanks for your help.
Old Oct 10, 2008 | 10:16 AM
jnb5101's Avatar
jnb5101
rear toe-in is the only hard part, because it's impossible(or at least very difficult) to get a center line on the frame and set the toe to that. that's what the computerized alignment machines can do for you.
i struck a deal with a local shop that allowed me to bring the car in several times to check the results of the changes that i made. after 4 trips, i got the numbers that i wanted.
question-why don't you trust aligment shops? if you had a poor experience with one, go to another. there's hundreds of them.
i did mine because nobody wanted to do it-it takes the tech too long to do a 4 wheel on an old vette.
Old Oct 10, 2008 | 07:57 PM
h2ohouse's Avatar
h2ohouse
Default this should help
http://www.fastcorvette.com/AlignmentSchool.htm
To align rear suspension
