Battery drawdown
Old Oct 13, 2008 | 02:34 PM
bsizemore's Avatar
bsizemore
1st Gear
Default Battery drawdown
I have a 1980 Corvette and I just put a new battery in it a few weeks ago. The problem is it will not hold a charge more than 24 hours. Any suggestions?
Old Oct 13, 2008 | 02:37 PM
SteyrAUG's Avatar
SteyrAUG
Wouldn't that be an alternator problem?
Old Oct 13, 2008 | 03:14 PM
Durango_Boy's Avatar
Durango_Boy
Charge the battery totally outside of the car or disconnected, and test it to make sure the charge doesn't fall on it's own. Batteries can lose a charge on their own if they are malfunctioning.
If it holds the charge on it's own for at least 24 hours, then connect it back to the car. Then, remove the alternator, take it to a local specialty shop that works on alternators and starters, and have them test it.
If it's bad, have them rebuild it. If it's good, go back, install it, and use this paper to find your draw.
http://photos.imageevent.com/durango...%20Testing.pdf
Old Oct 13, 2008 | 06:08 PM
7T1vette's Avatar
7T1vette
Is your interior light auto-dimmer working properly? Lots of folks have the same problem due to the dimmer module failing with an internal "short". Disconnect the module and see if it stays charged.
To Battery drawdown
