New Intake !!!!!??????
Old Oct 14, 2008 | 04:26 PM
DL9179's Avatar
DL9179
Default New Intake !!!!!??????
I just got a used rpm air gap off the forum here and had it powder coated , my question is Edelbrock web site says to use a special bolt kit for this intake . Does anybody know what is so special about the kit i curently have an ARP bolt kit that i used on my other intake ?
Old Oct 14, 2008 | 04:28 PM
Durango_Boy's Avatar
Durango_Boy
You don't need a special bolt kit.
Old Oct 14, 2008 | 06:32 PM
rcread's Avatar
rcread
I think Edelbrock is just saying that if you need bolts for your intake manifold, use their part number 8504. They are just regular intake manifold bolts. You might need a special hood, though, to fit over that intake manifold.
Old Oct 14, 2008 | 09:28 PM
chris75stingray's Avatar
chris75stingray
i just put one on my 75. used regular bolts and fit under hood with drop base aircleaner
Old Oct 15, 2008 | 10:13 AM
DL9179's Avatar
DL9179
Great thanks , yea i have a drop base w/about 1inch clearance from the stock hood !
Old Oct 15, 2008 | 10:37 AM
nate99's Avatar
nate99
Well, if the toddler in your avatar doesn't cause any clearance issues, the manifold should not be a problem.
Old Oct 15, 2008 | 03:35 PM
rcread's Avatar
rcread
With the drop base, just make sure you have enough clearance between the vent tube and the air cleaner lid.
To New Intake !!!!!??????
