HELP / Missing '75 Corvette interior windshield wiper control bezel mtg screws
I removed the interior windshied wiper control bezel and have misplaced the (5) mtg screws. Problem: What size of screws do i need??? If anyone has any info re: This issue, i would be grateful for your shared knowledge. Thank you!
[from memory only] I believe that they are 3/4" long, #8 sheet metal screws with Phillips drive oval heads....painted semi-flat black.
THANK YOUR FOR YOUR RESPONSE.
IT APPEARS THAT (3) ARE SHEET METAL SCREWS w/ PHILLIPS HEADS AND THEN THERES (2) OTHER THREADED SCREWS w/ ROUND FLAT HEADS....THE PROBLEM IS KNOWING WHAT SIZE ETC THEY ACTUALLY ARE.
'75 w/shield wiper control switch bezel mtg screws
Thank you for the suggestion, however ecklers corvette or mid american corvette don't list screws for this part. The chev. Dealers original books don't list them neither, so its been hard to buy.
