73 Rear Brake Dragging
Old Oct 17, 2008 | 06:03 PM
RetiredMarine20's Avatar
RetiredMarine20
Default 73 Rear Brake Dragging
73 with right rear brake dragging. Smoked the pads. Pulled off the caliper and all four pistons are free. Parking brake is free. Car has 42,000 miles and all four calipers were replaced at about 30,000. Car has set alot in the last 8 years. Appears to have pressure in lines when car is not running. Any Ideas?
Old Oct 17, 2008 | 06:11 PM
...Roger...'s Avatar
...Roger...
Rubber brake hose plugging up.
Old Oct 17, 2008 | 06:23 PM
RetiredMarine20
Going to check it now.
Old Oct 17, 2008 | 06:26 PM
GTR1999's Avatar
GTR1999
Agree , sounds like the hose isn't releasing the caliper. If they are over 5 years old replace them all, bleed the system every year if you store the car for a few months or every 2-3 years otherwise.
Old Oct 17, 2008 | 06:42 PM
RetiredMarine20
Beer for you if you are ever at Camp Lejeune. BTW I am from Eaton. Thanks.
Old Nov 2, 2008 | 06:47 PM
justinw2116's Avatar
justinw2116
Default I had this exact problem!
It was the brake booster going out. For some reason it seemed it was not releasing the vacuum. Instead of working on a rebuild I just went and picked up a Brake Booster & Master Cylinder combo for about $130. I also had 2 calipers replaced before finding out that the booster was jacked up.
To 73 Rear Brake Dragging
